By Ambro
#19535 I am using NodeMCU firmware flasher ( the one having black background ).
Now it is responding to the AT commands: THIS IS GREAT ! thank you very much.
Next: what bin should i flash_in to get LUA capable firmware ( just the same of your one ) ?
Ambro
By Ambro
#19536 I am getting the following on the ESPLorer now:
PORT OPEN 9600
HéÉ쨤¤ÌØi>øì´lb<àlñ@>häø
NodeMCU 0.9.5 build 20150318 powered by Lua 5.1.4
lua: cannot open init.lua
Please let me know if i am doing it right .
Ambro
By twaymouth
#19542 Yep, that is looking like it is back to normal and that we are on the same firmware versions. What I would recommend is downloading the latest version of ESPlorer (2.0 rc2) and in settings disable "auto save to ESP" that way when you are working on your code it won't try to save to the ESP until you are ready. From here you should be able to create and save to the ESP "init.lua" using the code I posted earlier and then upload the other 2 files required for the web server.
By Ambro
#19562 I am very happy since I did recover the operation of TWO esp_01's.
Your suggestion is very important : good to know!
I will try the files loading tonight since I am just a little bit busy now.
Where are you located ? I live in the north part of Italy ( GMT+1 + 1 DLST= GMT+2 )
>> How could I found a good explanation of the various buttons available in the ESPlorer ?
Thanks
Ambro
