By Ambro
#19758 these are the other files:
wifi.setmode(wifi.STATION)
--Change to match your network
--wifi.sta.config("SSID","PASSWORD")
wifi.sta.config("TP-LINK_XX","yyyyy")
wifi.sta.connect()
tmr.alarm(1, 1000, 1, function()
if wifi.sta.getip()== nil then
print("IP unavaiable, Waiting...")
tmr.stop(1)
print("Connected, IP is "..wifi.sta.getip())
dofile("ds18b20-web.lua")
end)
-- Set module name as parameter of require
local modname = ...
local M = {}
_G[modname] = M
-- Local used variables
-- DS18B20 dq pin
local pin = nil
-- DS18B20 default pin
local defaultPin = 3
-- Local used modules
-- Table module
local table = table
-- String module
local string = string
-- One wire module
local ow = ow
-- Timer module
local tmr = tmr
-- Limited to local environment
setfenv(1,M)
-- Implementation
C = 0
F = 1
K = 2
function setup(dq)
pin = dq
if(pin == nil) then
pin = defaultPin
ow.setup(pin)
function addrs()
setup(pin)
tbl = {}
ow.reset_search(pin)
repeat
addr = ow.search(pin)
if(addr ~= nil) then
table.insert(tbl, addr)
tmr.wdclr()
until (addr == nil)
return tbl
function readNumber(addr, unit)
result = nil
setup(pin)
flag = false
if(addr == nil) then
count = 0
repeat
count = count + 1
tmr.wdclr()
until((addr ~= nil) or (count > 100))
return result
crc = ow.crc8(string.sub(addr,1,7))
if (crc == addr:byte(8)) then
if ((addr:byte(1) == 0x10) or (addr:byte(1) == 0x28)) then
-- print("Device is a DS18S20 family device.")
ow.reset(pin)
ow.select(pin, addr)
ow.write(pin, 0x44, 1)
-- tmr.delay(1000000)
present = ow.reset(pin)
ow.write(pin,0xBE,1)
-- print("P="..present)
data = nil
data = string.char(ow.read(pin))
for i = 1, 8 do
data = data .. string.char(ow.read(pin))
-- print(data:byte(1,9))
crc = ow.crc8(string.sub(data,1,8))
-- print("CRC="..crc)
if (crc == data:byte(9)) then
t = (data:byte(1) + data:byte(2) * 256)
if (t > 32767) then
t = t - 65536
if(unit == nil or unit == C) then
t = t * 625
elseif(unit == F) then
t = t * 1125 + 320000
elseif(unit == K) then
t = t * 625 + 2731500
return nil
t = t / 10000
-- print("Temperature="..t1.."."..t2.." Centigrade")
-- result = t1.."."..t2
return t
tmr.wdclr()
-- print("Device family is not recognized.")
-- print("CRC is not valid!")
return result
function read(addr, unit)
t = readNumber(addr, unit)
if (t == nil) then
return nil
return t
-- Return module table
return M
Ambro
By Ambro
#19802 Twaymouyh,
I really do not understand what problem is causing the NO response on the web and on the browser.
Any direction ?
Thanks
Ambro
By twaymouth
#19803 From what I can see all your code looks fine however I have found that if I update my code I need to close the browser tab and re open it before I can get a response. I am currently at work but once I get home I will upload all the files that I am using to produce the rounded temperature reading and hopefully you can use them to achieve the same result.
