- Fri Jul 03, 2015 12:36 pm
#22367
I've gotten a little further down this rabbit hole.
It seems I can enable the promiscuous mode while I am still an AP by calling wdev_go_sniffer, HOWEVER, it seems to prevent any packets from entering the 802.11 engine then. So, in the promiscuous callback, I used this neat function to stack dump.
Code: Select all for( i = 0; i < 20; i++ )
ets_sprintf( ct, " %p\n", *((&i)+i) );
uart0_sendStr( ct );
And tracked it back to here... It seems the callback is actually called by ppProcessRxPktHdr, but, it looks like this function has nothing to do with processing packets normally, so I'm trying to find the normal packet path, so I can manually call the function that hands the packets off to the 802.11 stack, but alas, there are no references here, and the next thing up on my stack, 0x402459c0... Scratch a Bit pukes all over and can't interpret because of so many unkown opcodes. I have no idea how I'd progress from here...
P.S. the beqz is checking to see if there's a callback, if not, it frees buffers and immediately exits, so I /really/ need to know what lies right after this function in 0x402459c0 if I want go call the 802.11 receive function.
Code: Select all┌──────────────────────────────────────────────────────────────────────────│40245884 ; xref: 0x4024588f r
│40245884 dat_40245884:
│40245884 a88cfe3f dd 0x3ffe8ca8
│40245888 ppPeocessRxPktHdr:
│40245888 12c1f0 addi sp, sp, -0x10
│4024588b c911 s32i.n a12, sp, 0x4
│4024588d cd02 mov.n a12, a2
│4024588f 21fdff movi* a2, 0x3ffe8ca8 ; via 0x40245884
│40245892 0901 s32i.n a0, sp, 0x0
│40245894 0802 l32i.n a0, a2, 0x0
│40245896 169004 beqz a0, loc_402458e3
│40245899 320c01 l8ui a3, a12, 0x1
│4024589c 020c04 l8ui a0, a12, 0x4
│4024589f 303641 srli a3, a3, 6
│402458a2 9c03 beqz.n a3, loc_402458b6
│402458a4 004741 srli a4, a0, 7
│402458a7 261449 beqi a4, 0x1, loc_402458f4
│402458aa 005064 extui a5, a0, 0, 7
│402458ad e68543 bgei a5, 0x8, loc_402458f4
│402458b0 620c07 l8ui a6, a12, 0x7
│402458b3 67e63d bbsi a6, 6, loc_402458f4
│402458b6 ; xref: 0x402458a2 j
│402458b6 loc_402458b6:
│402458b6 720c0c l8ui a7, a12, 0xc
