By WStan
#23550
martinayotte wrote:That's why the specs mentionned using a mosfet directly to VCC ... ;)
(But of course, on software side, it is a bit more complex since you need to cut that supply before receiving the data)
I tested the system with different resistor values, and I managed to read up to 3 sensors. (R = 0.76k). I just have to buy MOSFET :)
Thank You
By Flip
#23575 This problem may base on the fact that the esp is only 3.3v instead of 5 v. Try to connect the Pullup to 5v and wire 2 pairs of antiparalell diodes between the Sensors string/pullup and the digital io of the ESP to get a data bus voltage level of at least 4.5V. Good luck!
