By steve_carter
#23851 I received my unit and in standalone AP mode SID was AITHINKER-LAST3MAC. after I flashed it with blank.bin from 0x7E000 this changed to ESP_LAST3MAC.
I am interested in changing this to my own name just for kicks. Does anyone know the address to do this?
By martinayotte
#23856 You can do this programmatically by using the following (from user_interface.h)
Code: Select allstruct softap_config {
    uint8 ssid[32];
    uint8 password[64];
    uint8 ssid_len;     // Note: Recommend to set it according to your ssid
    uint8 channel;      // Note: support 1 ~ 13
    AUTH_MODE authmode; // Note: Don't support AUTH_WEP in softAP mode.
    uint8 ssid_hidden;  // Note: default 0
    uint8 max_connection;       // Note: default 4, max 4
    uint16 beacon_interval;     // Note: support 100 ~ 60000 ms, default 100
bool wifi_softap_get_config(struct softap_config *config);
bool wifi_softap_get_config_default(struct softap_config *config);
bool wifi_softap_set_config(struct softap_config *config);
bool wifi_softap_set_config_current(struct softap_config *config);
EDIT : I've also found an example here http://bbs.espressif.com/viewtopic.php?f=21&t=227
