By hudis
#24004 Hello
I’m quite new to arduino and esp8266. Currently I’m trying a simple thing – connect arduino UNO to wifi network using ESP8266 and read a webpage from the internet.
I’m using the AT firmware on ESP8266. I can connect it to wifi and open a TCP connection to web server, pass the URL I want to receive, but I have the following problem:
while (Serial.available()){
char c = Serial.read();
dbgSerial.write(c);
strReceived+=c;
This gives me exactly what I need to my debug console – the whole HTTP response together with the content. The moment I comment out the debug output to soft serial, I only get very little data from the server. When I add a delayMicroseconds(50) after Serial.read(), I get a little more data to strReceived, but never as much as when I use the serial debug.
strReceived+=c;
delayMicroseconds(50);
dbgSerial.println(strReceived);
the above code gives me some data, but never the whole HTTP reply (header and page itself), usually some characters are missing.
any advice?
AT+GMR output:
AT version:0.21.0.0
SDK version:0.9.5
thank you very much
By hudis
#24146 I have tried everything between 300bps to 115200 bps on hardware serial and 300bps - 9600 bps on software serial
I tried turning off interrupts at various places in my sketch, I tried different delay times, I tried Mega 2560, Uno...
the best results I have when I dont's use the serial.available() function but read blindly from the serial in a loop such as for (i=1, 1<500, i++) {ch=serial.read(); strReceived+=ch} which fills the strReceived string object with a lot of junk, but catches the most of incoming data.
I can't tell whether it's the cheap chinese arduino's fault, timing problem, buffer problem or what.
if anyone would like to pass me the result of their test I would be very grateful. My current sketch is:
Code: Select all/*
actually 2 sketches in one, controlled by the define statement.
 one part of code only copies characters between the esp8266 and USB serial. I put it here so I don't have two different sketches, one for serial console and one for the actual webclient
#include <SoftwareSerial.h>
#define HOSTNAME    "www.baidu.com"
#define HOSTPORT    80
#define HTTP_HEADER " HTTP/1.1\r\nHost: http://www.baidu.com\r\nConnection: close\r\n\r\n"
//#define esp Serial1
#define dbg Serial
#define esp dbgSerial
#define DTESPEED 9600
//#define PASSTHROUGH
#define WEBCLIENT
#define timeBetweenRequests 500
SoftwareSerial dbgSerial(10, 11); // RX, TX
  dbg.begin(9600);
  delay(100);
  dbg.setTimeout(15000);
  esp.begin(DTESPEED);
  delay(100);
  esp.setTimeout(15000);
#ifdef PASSTHROUGH
  dbg.print("Passthrough mode. Our DTE speed is now ");
  dbg.println(DTESPEED);
  dbg.println("reset: AT+RST | firmware: AT+GMR | baudrate: AT+CIOBAUD=9600");
  dbg.println("list AP: AT+CWLAP | IP config: AT+CIFSR | join AP: AT+CWJAP=\"ssid\",\"pass\"");
  dbg.println("where joined: AT+CWJAP? | lcal echo: ETE1, ATE0");
#endif
  delay(1000);
#ifdef PASSTHROUGH
 while (dbg.available()){
      char ch=dbg.read();
      esp.write(ch);
  while (esp.available()){
      char ch=esp.read();
      dbg.write(ch);
#endif
#ifdef WEBCLIENT
  String cmd="";
  bool tcpEstablished=false;
  bool readyToSend=false;
  bool readyToReceive;
  dbg.println("Starting");
  delay(timeBetweenRequests);
  String URL="GET /robots.txt";
  URL+=HTTP_HEADER;
  cmd="ATE0";
  esp.println(cmd);
//  dbg.println(cmd);
  delay(100);
      delayMicroseconds(40);
      char ch=esp.read();
      dbg.write(ch);
  cmd="AT+CWJAP?";
  esp.println(cmd);
  delay(100);
//  esp.find("OK");
      char ch=esp.read();
      dbg.write(ch);
  cmd="AT+CIFSR";
  esp.println(cmd);
  delay(100);
//  esp.find("OK");
      char ch=esp.read();
      dbg.write(ch);
  String strReceived="";
  cmd = "AT+CIPSTART=";
  cmd += "\"";
  cmd += "TCP";
  cmd += "\",\"";
  cmd += HOSTNAME;
  cmd += "\",";
  cmd += HOSTPORT;
  esp.println(cmd);
  if(esp.find("CONNECT")){
    dbg.println("\r\nFound CONNECT");
    tcpEstablished=true;
  } else {
    dbg.println("\r\nDid not find CONNECT");
  if (tcpEstablished){
    cmd = "AT+CIPSEND=";
    cmd += URL.length();
    esp.print(cmd);
    esp.print("\r\n");
    if(esp.find(">")){
       dbg.println("Found >");
       readyToSend=true;
    } else {
       dbg.println("Did not find >");
  if (readyToSend){
    cmd=URL;
    esp.print(cmd);
    esp.print("\r\n");
    dbg.println(cmd);
    if(esp.find("+IPD,")){
      dbg.println("Found +IPD,");
      readyToReceive=true;
    }else {
      dbg.println("Did not find +IPD,");
  strReceived="";
  if(readyToReceive){
    while (esp.available()>0){
      char ch=esp.read();
      strReceived+=ch;
 //     dbg.write(ch);
      delayMicroseconds(10);
  dbg.println("-=-=-=-=-=-=- Received from URL: -=-=-=-=-=-=-");
  dbg.println(strReceived);
  dbg.println("------------- End of transmission ------------");
#endif
By hudis
#24162 Ok guys, now I'm really puzzled.
I did the following:
I installed the esp8266-arduino into arduino IDE and re-flashed my ESP8266-1 board with the following sketch (so I don't have the AT firmware on it anymore):
const char* ssid     = "my_wifi";
const char* password = "my_password";
const char* host = "www.baidu.com";
  Serial.begin(9600);
  delay(10);
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
int value = 0;
  delay(5000);
  ++value;
  Serial.println(host);
  WiFiClient client;
  const int httpPort = 80;
    return;
  // We now create a URI for the request
  String url="/robots.txt";
  Serial.println(url);
               "Host: " + host + "\r\n" +
               "Connection: close\r\n\r\n");
  delay(1000);
  while(client.available()){
    Serial.print(line);
  delay(10000);
And I uploaded the following to Arduino Uno:
Code: Select all#include <SoftwareSerial.h>
#define dbg Serial
  dbg.begin(9600);
  delay(100);
  delay(100);
  delay(1000);
      char ch=esp.read();
      strReceived+=ch;
  if(strReceived.length()>0){
    dbg.print(strReceived);
This time I get the whole robots.txt webpage without any problems, so it seems to me the problem is with AT firmware.
