By maker1
#26663 O.K folks I tried several times to communicate with the esp03 with no luck.
So this time I'm going to write down the whole process and with your support we will make a step by step toturial.
Hardware:
1. Pc runing windows 7
2. Esp8266 esp-03
3. FT232RL FTDI USB 3.3V 5.5V to TTL Serial Adapter
Software:
1. Serial terminal: coolterm or Termite
Wiring Diagram:
Updated after By Barnabybear - Fri Aug 21, 2015 12:01 pm reply post
Actual Layout:
Actual Layout
Connecting Esp 03 to Power 3.3v
I have a profesional external power supply set to 3.3v
Connecting Esp 03 to PC
Conecting the mini usb to PC USB port (drivers were installed earlier)
Trying to communicate per(http://www.instructables.com/id/ESP8266-based-web-configurable-wifi-general-purpos/?ALLSTEPS:
1) leave GPIO0 floating.
2) Access the serial interface with a terminal program- I use Termite, my port is com5.
3) Set the terminal s/w baud rate to either 57600 or 115200 - I tried 9600 .. 115200
4) Power-up the ESP8266 and you should see some readable text indicating that it's ready. - NOTHING HAPPNING
5) If you get nonsense try changing the baud rate. If all is well, try some AT commands.
6) Try AT+RST which should re-start the module.- NOTHING HAPPNING
7) Try AT+GMR which should give the firmware version. - NOTHING HAPPNING
Anyone have an idea how to proceed?
By maker1
#26671 1) leave GPIO0 floating.
4) Power-up the ESP8266 and you should see some readable text indicating that it's ready. - I SEE
The line feeding is continuously and to stop it I need to disconnect the power
