By Mmiscool
#26924 Your best bet to get up and running quickly is node mcu lua.
Its how i got started with these things.
On the other hand you can program them directly with the arduino environment by using esp826 arduino. No need for any firmware.
I will also make a shameless plug for http://es8266basic.com and the basic interpreter firmware but that is a project of mine.
But I would defiantly start with node mcu firmware. I put together a tutorial on how to install it here.
http://www.smbisoft.com/projects/esp8266
By digiajay
#27284 Hi have successfully flashed with the bin file "nodemcu_float_0.9.6-dev_20150704.bin" :)
But after that, I couldn't open the COM port with the ESP :o :shock: . It throws some no response error like below
Code: Select allPORT OPEN 115200
Communication with MCU...
Got answer! AutoDetect firmware...
Can't autodetect firmware, because proper answer not received.
PORT CLOSED
:shock: . Please help me.
