By sej7278
#5407
Harold L. wrote:You could continue from step No.5 of the tutorial: http://nodelua.org/doc/tutorial/make-your-first-node/, step No.6 and 7 is also important.
The Node WebIDE is designed for programming with Lua more convenient, it's a different concept with the cloud service, just make a try will give you some different experience ;)
nah i'm not a cloud ide fan, went through all that crud with the spark core.
so you don't have any way to use ip other than via your cloud? there's no way to run a webserver or telnet server like with the AT or nodemcu (yuk) firmware?
By picpic020960
#5409 Bonjour ,
why not the bin file of the project in github folder ?
all the projects with ESP are not easy to compile !
win / linux / toolchain / expressif / sdk 0.9.n
it's like opensource when the source is in folder
and it's easy to test the app
what you think about ?
By Harold L.
#5506
Client socket API had been partly implemented in NodeLua, but undocumented. I will be very appreciated if you can improve it.
You can find them in app/lua/lnode_net_socket.c
It wasn't enabled by default, you can edit app/lua/linit.c and uncomment the line to use it:
//{LUA_LNODE_NET_NAME, luaopen_lnode_net},
By Harold L.
#5507
picpic020960 wrote:Bonjour ,
There is prebuild firmware on the website, you'll find it here: http://nodelua.org/doc/download_firmware/
