kluszon wrote:I tried it, but it don't work too.
@EDIT - Problem Solved!
1. You can't manual send GET or POST request using Arduino IDE and Arduino Serial Monitor, becauese there is problem with coding "\r\n" - carriage return and new line. ( At least I can't do this, though I spent a lot of time on it)
2. Very important things are delays ( delay() ) between AT commands.
3. Correct GET request.
I correct all errors and everything is working fine!
Below I attached my code:Code: Select all#include "SoftwareSerial.h"
SoftwareSerial ESP8266(2, 3);// RX, TX
String server = "adres_serwera"; // np. www.examble.pl albo adres ip 129.75.1.32
void setup()
ESP8266.begin(115200); //odpowiednia prędkość dla twojego modułu
Serial.print("Start");
reset();
ESP8266.println("AT+CWMODE=1");
delay("1000");
ESP8266.println("AT+CIPMUX=1");
delay("1000");
connectWifi();
void loop()
String cmd;
cmd = "AT+CIPSTART=1,\"TCP\",\"";
cmd += server;
cmd += "\",80";
ESP8266.println(cmd);
if(ESP8266.find("OK"))
Serial.println("Connected to the web!");
float weight = 257;
bool state = 1;
cmd = "GET /skrypty/add_k.php?w=" + (String)weight + "&k=" + (String)state + " HTTP/1.1\r\n";
cmd += "Host: www.kluszon.cba.pl\r\n\r\n";
ESP8266.print("AT+CIPSEND=1,");
ESP8266.println(cmd.length());
if(ESP8266.find(">"))
Serial.println(">");
Serial.println("send!");
void connectWifi()
String cmd = "AT+CWJAP=\"My_wifi\",\"hasło\"";
delay(4000);
Serial.println("Connected!");
}else{
connectWifi();
Serial.println("Cannot connect to wifi");
void reset()
ESP8266.println("AT+RST");
delay(1000);
if(ESP8266.find("OK")) Serial.println("Module Reset");
i try your code but it dont work
![Sad :(](./images/smilies/icon_e_sad.gif)
