Page 2 of 2
Re: Get voltage and use A0 pin
PostPosted: Sat Apr 16, 2022 4:38 pm
by Inq720
You wouldn't be in the same class with https://www.esp8266.com/viewtopic.php?f=11&t=23633#p94275... would you? :lol:
PostPosted: Sat Apr 23, 2022 7:40 am
by array81
Inq720 wrote:You wouldn't be in the same class with https://www.esp8266.com/viewtopic.php?f=11&t=23633#p94275... would you? :lol:
I have created a sophisticated control unit for irrigation based on esp32 and now.
I would like to create a probe to turn on the control unit for irrigation only when the ground brightness is low. I would like to use an esp8266 (wemos d1 mini) with battery and deep sleep. I would therefore like to measure the battery voltage to have an alarm when it is running low.
Can anyone tell me if the component I found on aliexpress could use me useful for measuring both the battery voltage and the sensor value?
PostPosted: Sun Apr 24, 2022 11:54 am
by Bonzo
Have you checked out the moisture sensor before you get to far? I brought a couple and they are crap.
I have used these in the past and they have worked well: ADS1015 ADC 12-bit ADC Module
As I said earlier you should get a better accuracy with one of these rather than using the built in analog pin.
You could use a couple of MOSFET's to create switches to select the different inputs.
The max voltage input on the anolg pin is 3.2V - I should say the maximium voltage the ADC can read is VDD + 0.3
