By akhgari
#60889
martinayotte wrote:Fiest, you are talking about AT command, but you are using an Arduino sketch.
Beware that when you upload Arduino sketch, the AT firmware is gone/erased.
For you code, I don't see any client.available(), so it doesn't check if characters are received.
Check the following code instead :
Code: Select allvoid loop()
  if (client) {
    if (client.available()) { // <--- here is the missing part
      Serial.println(req);
      client.flush();
      Serial1.println("Client disonnected");
Yes! I know. I use terminal and AT commands to check my mobile app. this app have several buttons and when press each buttons on mobile app, send a string on port "8888" that received on terminal
now erase firmware and wish write a skatch to read this string and turn on/off gpio
I use Arduino 1.8.0 downloaded from arduino.org and "http://arduino.esp8266.com/stable/package_esp8266com_index.json"
I compile your code but following error reports
exit status 1
'class ESP8266WebServer' has no member named 'available'
By akhgari
#61071 Thanks martinayotte
I changed my code
const char *ssid = "Test_ESP";
const char *password = "testtest";
unsigned int localPort = 8888;
IPAddress    apIP(192, 168, 56, 1);
IPAddress    broadcastIP(255, 255, 255, 255);
WiFiServer server(localPort);
  delay(1000);
  Serial.print("Configuring access point...");
  WiFi.mode(WIFI_AP);
  WiFi.softAPConfig(apIP, apIP, IPAddress(255, 255, 255, 0));
  WiFi.softAP(ssid, password);
  server.begin();
void loop()
  if (client) {
      client.flush();
I use your code and delete ESP8266WebServer. now it's compile with out any error but nothing show in serial monitor.
