By gadigr
#8338
l0ur3nz0 wrote:You may need a proper PSU. you cam use one from a desktop computer. I use a breadboard PSU.
Can you communicate using the FTDI?
I cant seem to find the appropriate drivers for the FTDI..
i have the ftdi232 but its drivers doesnt seem to install properly
suggestions?
By alonewolfx2
#8345 Firstly arduinos software serial cant working correctly with esp. It have different frame. You can use hardware serial. But if you need just serial debugger you can use arduinos serial apadter directly tx and rx pin. But you need 3.3v good power for esp. Arduino nano 3.3v pin not enough.
suggestions?
By l0ur3nz0
#8348
suggestions?
huuuummm
FTDI has good support. But I know there was problems with some chinese clones being blown by some update... Which OS are you using?
