By UnconstructiveTab
#89124 I'm making a program that can dynamically push text or color or brightness to a neopixel matrix. This code works, but after about 5min the ESP8266 resets all of a sudden with no reason. Also, unrelated, I can't access the serial monitor for anything.
#include <ESP8266WebServer.h>
#include <Adafruit_GFX.h>
#include <Adafruit_NeoMatrix.h>
#include <Adafruit_NeoPixel.h>
static const uint8_t gif[] PROGMEM = {
   0x47, 0x49, 0x46, 0x38, 0x39, 0x61, 0x1b, 0x00, 0x05,
   0x00, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
   0x00, 0x21, 0xf9, 0x04, 0x01, 0x00, 0x00, 0x01, 0x00,
   0x2c, 0x00, 0x00, 0x00, 0x00, 0x1b, 0x00, 0x05, 0x00,
   0x00, 0x02, 0x1a, 0x44, 0x0c, 0x79, 0x9a, 0xb8, 0x8e,
   0x60, 0x98, 0x86, 0xce, 0x83, 0x65, 0x8b, 0xfc, 0xe5,
   0x2a, 0x65, 0x97, 0x65, 0x85, 0x63, 0xe3, 0xa1, 0xaa,
   0x08, 0x15, 0x00, 0x3b,
const char* ssid = "matrix";
const char* password = "12345678";
ESP8266WebServer server(80);
#define PIN D4
bool current_changed = false;
String current_text = "HELLO";
int current_color[3] = {255, 0, 0};
int current_brightness = 50;
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(32, 8, PIN,
   NEO_MATRIX_BOTTOM + NEO_MATRIX_RIGHT +
   NEO_MATRIX_COLUMNS + NEO_MATRIX_ZIGZAG,
   NEO_GRB + NEO_KHZ800);
   WiFi.softAP(ssid, password);
   IPAddress local_ip(10,0,1,1);
   IPAddress gateway(10,0,1,1);
   IPAddress subnet(255,255,0,0);
   WiFi.softAPConfig(local_ip, gateway, subnet);
   server.on("/", []() {
      char gif_colored[sizeof(gif)];
      memcpy_P(gif_colored, gif, sizeof(gif));
      server.sendHeader("Commmand-Response", current_text + "~" + current_color[0] + "," + current_color[1] + "," + current_color[2] + "~" + current_brightness);
      server.send(200, "image/gif", gif_colored, sizeof(gif_colored));
   server.on("/c2c", []() {
      server.sendHeader("Access-Control-Allow-Origin", "*");
      if(server.hasArg("cmd")) {
         if(server.arg("cmd") == "text") {
            current_text = server.arg("value");
            current_changed = true;
            server.sendHeader("Commmand-Response", current_text);
         if(server.arg("cmd") == "color") {
            int red = server.arg("red").toInt();
            int green = server.arg("green").toInt();
            int blue = server.arg("blue").toInt();
            current_color[0] = red;
            current_color[1] = green;
            current_color[2] = blue;
            matrix.setTextColor(
               matrix.Color(current_color[0], current_color[1], current_color[2])
               server.arg("red") + "," +
               server.arg("green") + "," +
               server.arg("blue")
         if(server.arg("cmd") == "brightness") {
            current_brightness = server.arg("value").toInt();
            matrix.setBrightness(current_brightness);
            server.sendHeader("Commmand-Response", server.arg("value"));
   server.onNotFound([]() {
   matrix.begin();
   matrix.setTextWrap(false);
   matrix.setBrightness(5);
      matrix.Color(255, 0, 0)
   server.begin();
int z = 0;
int x = matrix.width();
int pass = 0;
int pixels = 0;
   server.handleClient();
   pixels = ((current_text.length() * 6) + 10) * -1;
   if(current_changed) {
      x = matrix.width();
   matrix.fillScreen(0);
   matrix.setCursor(x, 0);
   matrix.print(current_text);
   if(--x < pixels) {
      x = matrix.width();
   matrix.show();
   delay(100);
