By Linton_Samuel_Dawson
#26210 Hello everybody, I'm new here but I'm playing around with Arduino since a few months, and I got this month some ESP8266 01 to play with..
Actually I'm working with AT commands, and everything seems to go well... The only thing that I can't get to work is to create a correct GET request..
What I'm trying to do is getting the numbers from this page: http://coolparis.azundo.com/
They are just three different temperature in Paris, a friend of mine set that up with a Python script.
I can connect to it with:
AT+CIPSTART=2,"TCP","coolparis.azundo.com",80
but then I'm stuck with:
AT+CIPSEND=2,20
OK
> GET / HTTP/1.0\r\n
SEND OK
+IPD,2,173:<html>
<head><title>400 Bad Request</title></head>
<body bgcolor="white">
<center><h1>400 Bad Request</h1></center>
<hr><center>nginx/1.0.12</center>
</body>
</html>
2,CLOSED
I'm trying different combinations, using also
GET / HTTP/1.1\r\n\r\n
but I always get back a Bad request..
anyone has any idea on how to get that data?
I am missing something fundamental?
Thank you!
#26216 thank you for answering :D
yutonet wrote:try this:
Code: Select allGET http://coolparis.azundo.com/ HTTP/1.0\r\n\r\n\r\n
(also change the CIPSEND char length accordingly)
just to be sure, is it working for you?
because here this happens:
Code: Select allAT+CIPSTART=2,"TCP","coolparis.azundo.com",80
2,CONNECT
OK
AT+CIPSEND=2,55
OK
SEND OK
+IPD,2,173:<html>
</body>
</html>
2,CLOSED
maybe I'm missing something else earlier?
