By kolban
#26566 Howdy my friend, I don't think you have given nearly enough information to allow the community to assist you. What is the nature of the problem that you are seeing? What does your code look like? What do you "see" when you attempt?
Neil
By sohialsadiq
#26625
kolban wrote:Howdy my friend, I don't think you have given nearly enough information to allow the community to assist you. What is the nature of the problem that you are seeing? What does your code look like? What do you "see" when you attempt?
Neil
Hello Neil,
i am just a beginner in nodemcu using 12E model, few days ago it was working fine it
but when i install arduino IDE again it upload all sketch on 0X0000000
when i upload sketch this happen
Global variables use 48,696 bytes (59%) of dynamic memory, leaving 33,224 bytes for local variables. Maximum is 81,920 bytes.
Uploading 304864 bytes from C:\Users\SOHAIL~1\AppData\Local\Temp\build5585173374228934113.tmp/WiFi_AP_java4.cpp.bin to flash at 0x00000000
i don't know what is wrong.
By sohialsadiq
#26626
Neil
Hello Neil,
Sketch uses 300,716 bytes (28%) of program storage space. Maximum is 1,044,464 bytes.
