Re: New Working GCC for ESP8266
Posted: Sat Nov 29, 2014 10:52 am
joostn wrote:Anyway I did a make clean; make and now I get linker errors as well:Code: Select all"/opt/Espressif/crosstool-NG/builds/xtensa-lx106-elf/bin/xtensa-lx106-elf-g++" -L../../esp8266/esp_iot_sdk_V0.9.2/lib -L ../../esp8266/esp_iot_sdk_V0.9.2/ld/ -Teagle.app.v6.cpp.ld -Wl,--no-check-sections -u call_user_start -Wl,-static -nostdlib -Xlinker -Map=build/test1.map -Wl,--gc-sections build/obj/uart.o build/obj/main.o build/obj/jnuclib.o build/obj/jnucgpio.o build/obj/jnucasync.o build/obj/jnuckeyboarddebouncer.o build/obj/jnuceventdispatcher.o build/obj/jnucinterruptonchange.o build/obj/jnucinterrupthandlers.o build/obj/jnucinternaltempsensor.o build/obj/jnucble.o build/obj/jnucblecommon.o build/obj/jnucblecentral.o build/obj/jnucdisplaybase.o build/obj/jnucbuffereddisplay.o build/obj/jnuccontrols.o build/obj/jnucpcd8544.o build/obj/jnucili9320.o build/obj/jnucst7735.o build/obj/jnucseps225.o build/obj/jnucsystick.o build/obj/jnucboards.o build/obj/jnucbitmap.o build/obj/jnucfonts.o build/obj/jnucWindowManager.o build/obj/jnucdialogs.o build/obj/someFonts.o build/obj/jnucrotary.o build/obj/jnuctimer.o build/obj/jnucservo.o build/obj/jnucuart.o build/obj/jnucstream.o build/obj/jnucnetcommon.o build/obj/jnuctcpserver.o build/obj/staticfunctionstub.o -o build/test1.out
/opt/Espressif/crosstool-NG/builds/xtensa-lx106-elf/lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: warning: cannot find entry symbol call_user_start; defaulting to 0000000040100000
build/obj/jnucasync.o:(.text._ZN4jnuc9function0IvE14invokeEmbeddedIZNS_10TimerQueueC1EvEUlvE0_EEvPKS1_+0x18): undefined reference to `system_os_post'
build/obj/jnucasync.o: In function `void jnuc::function0<void>::invokeEmbedded<jnuc::TimerQueue::TimerQueue()::{lambda()#2}>(jnuc::function0<void> const*)':
jnucasync.cpp:(.text._ZN4jnuc9function0IvE14invokeEmbeddedIZNS_10TimerQueueC1EvEUlvE0_EEvPKS1_+0xc6): undefined reference to `system_os_post'
build/obj/jnucasync.o:(.text._ZN4jnuc10TimerQueue19RescheduleInterruptEv+0xc): undefined reference to `system_get_time'
You don't link with libmain.a which defines call_user_start, system_os_post and system_get_time. Try adding -lmain (and probably other -l directives) to the linker command line.
