Re: Problem with linker in Xtensa
Posted: Wed Feb 11, 2015 3:54 pm
jcmvbkbc wrote:...and you have libc.a and all other missing libraries in the /opt/Espressif/ESP8266_SDK/lib on that other machine, right? And you don't have SDK_BASE in your environment?.
Yes, in the other machine i have this libs. I try to use the first tutorial to create the SDK_BASE but i forgot what i did to make with success this makefile, in the moment the other machine isn't with me and that's i need to setup the enviroment in this machine
jcmvbkbc wrote:Well, it does one strange thing, it creates ESP8266_SDK directory, and then it mv unpacked directory into it. I believe it had to rename the unpacked directory. I'll fix that.
And I think esp-open-sdk should be preferred SDK setup method.
Thanks, but i still have one doubt, if i prefer to use the esp-open-sdk i just need to make the repo and move the folder to the same directory to adjust the PATHs?
