By zarya
#1141 still having some issues compiling some of the examples
using this makefile (works for the at example) https://gist.github.com/zarya/7e1a08160bf3b7ac220f
if i try to compile the IoT Demo or https://github.com/cnlohr/dumbcraft8266 i am getting the error:
Code: Select allzarya@esp8266:~/source/IoT_Demo$ make
CC driver/adc.c
CC driver/gpio16.c
CC driver/i2c_master.c
CC driver/key.c
/tmp/ccLFnipI.s: Assembler messages:
/tmp/ccLFnipI.s:183: Error: literal pool location required for text-section-literals; specify with .literal_position
make: *** [build/driver/key.o] Error 1
By tinhead
#1143 try -mtext-section-literals
http://gcc.gnu.org/onlinedocs/gcc-4.1.2 ... tions.html
By jcmvbkbc
#1144
zarya wrote:if i try to compile the IoT Demo or https://github.com/cnlohr/dumbcraft8266 i am getting the error:
Code: Select allCC driver/key.c
Please share the complete command line used to compile driver/key.c and preprocessed source of the driver/key.c with that command line (just replace -c with -E to get it).
By mikelelere
#1147 I was experiencing the very same issue and the solution was including the -mno-text-section-literals in CFLAGS. This flag instructs the compiler to place literals in separate sections in the output file, rather than including them in the .text section (which is the effect of the -mtext-section-literals). Include such flag in CFLAGS and you should be able to compile.
