By cal
#21951
hreintke wrote:Hi Cal,
Yes definitely interested, will check other postings too to get understanding of current status.
Would it then also be possible to disassemble (parts of) sdk ? I am specialy intrested in the system_get_sdk_version().
I'd like to get the sdk version from libmain.a (or any other espressif lib) directly (win/linux)
Herman
Moin Herman,
you can use gdb for that as I demonstrated here: viewtopic.php?f=13&t=3756
But you can do that immediately using
Code: Select allobjdump -d executable|object file|library
Cal
By cal
#21959
alon24 wrote:what hardware do I need in order to debug?
I want ot , but need to get into this, and could not realy understand
Can you please explain more?
I added a few words to the initial posting. Follow the links to get more information.
Cal
By kenn
#21990
cal wrote:Dear IoT entusiasts!
Is there any interest on using a debugger like gdb to analyze your programs running on the esp8266?
Using gdb directly or one of the multiple frontends like eclipse you could
  • step to your code on C and/or assembler level,
  • inspect registers/variables/memory
  • set breakpoints in code,
  • set watchpoints on memory changes,
  • enter debugger on exceptions like exceptions 28 or 29 (illegal read or write access)
  • print and inspect call stacks
I am asking this because new replies on the threads talking about debuggers are discouraging low.
Is that because you think you can't help in building the debug solution or do you think it is not needed or useful or you don't know or don't care?
Curious,
Cal
Assuming that I might be typical of the many who jumped aboard the ESP8266 train, let me answer from my own perspective:
  • The ESP8266 and especially the available ecosystems (frameworks) are surprisingly robust and fully-featured; I've found that so far, anything that will compile and flash will run as expected. So i haven't yet been stuck for the lack of a full debugger.
  • It's easy to include debugging statements that output to serial at runtime
  • The dev cycle (write, compile, flash, monitor serial) is dependable and pretty fast.
  • I do have experience with debuggers in app dev environments, and from some smaller microcontroller IDEs, but not coming from a hard-core embedded background, I'm not that used to it (eg never used JTAG)
Nonetheless, I hope to grow in experience, and as my ESP8266 programs become more complex, a good debugger will become more important to me.
Hope this helps.
