By samehhady
#5548
ivanroberto wrote:Hi Cherts,
All of us have a lot of diferent needs (projects).
Could you teach us how to put a sample project to your IDE? (like: https://github.com/espressif/esp_iot_rtos_sdk)
Thanks
+1
It is definitely better than bugging you every time we need to add new project :D
By pvvx
#5572
samehhady wrote:Hi Cherts,
Thank you so much for this great tool, can you please add the new open source Lua NodeLua?
viewtopic.php?f=6&t=929
It looks very promising!
Extract files ‘NodeLuaMake.zip’ – folder NodeLua
Files nodemcu - folder nodemcu-firmware-master
Eclipse:
File->Import->General->Existing Project into Workspace->Next->Browse… folder NodeLua, Check ‘Copy projects into workspace’, Finish.
Select progect ‘NodeLua’ -> Import->File System->Next->From … nodemcu-firmware-master, Into folder: ‘nodelua’. Check all files, Uncheck ‘Makefile’ into right panel. Finish.
Compile…
