Using the new Arduino IDE for ESP8266 and found bugs, report them here
By CheapB
#15491
gerardwr wrote:
CheapB wrote:Yes, I was trying to provide the minimum code required to force the reset. I need the received UDP package in a string for further processing - hence the recv. How would you go about that?
Have a look at my example here, maybe it helps:
http://www.esp8266.com/viewtopic.php?f=29&t=2451
I tried this. It cuts off the last byte of the received UDP package and stops working in my environment. I am on windows 8.1.
By gerardwr
#15508
CheapB wrote:I tried this. It cuts off the last byte of the received UDP package and stops working in my environment. I am on windows 8.1.
If it cuts off the last byte you could change
Code: Select all    if (len > 0) packetBuffer[len] = 0;
into something like
Code: Select all    if (len > 0) packetBuffer[len+1] = 0;
By CheapB
#15552
into something like
Sure, that is not a bit issue. The bigger problem is it stops working after receiving 1 package..
By gerardwr
#15579
CheapB wrote:Sure, that is not a bit issue. The bigger problem is it stops working after receiving 1 package..
The sketch is OK on my Mac.
Could the problem be caused by the program you use to send the UDP packet?
I use Packet Sender for testing (also available for Windows).
