By madias
#17018 Hello, at first thank you all for this project!
I'm on OSX 10.9.5 and got mad with my ESP's (01 and 03). Upload seemed to work without problems, even a simple serial response code is working.
BUT: Any(!) WIFI example sketch won't work and the ESP hangs on start. Using the complete same configuration on parallels/Windows 7 everything is working perfect! So it's not a hardware issue and I use the same /hardware/ on both IDE's
More Details:
On OSX I got the message (with 74880 baud):
'rst cause:1, boot mode:(3,xxxx)'
and then nothing
So I guess there is something wrong with the uploader (ESPtool or script) on OSX. (I tried out 3 different USB/TTL/FTDI converter, and all of them are working perfect on other projects on OSX).
Thank you
regards
Matthias
