By SwiCago
#22930 Hi Chris,
I threw this together bases on my Captive portal code and the neopixel sample code. I wrote it in a text editor at work, so I have not yet compiled it or tested it...but this should get you in the right direction
Edit: updated code below. Had 2 typos and then compiled...But have not tested on ESP yet
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <NeoPixelBus.h>
#define pixelCount 4            //number of pixels in RGB strip
NeoPixelBus strip = NeoPixelBus(pixelCount, 0);  //GPIO 0
const char* ssid     = "MY_ROUTER";
const char* password = "MY_PASSWD";
IPAddress apIP(192, 168, 1, 1);        //FOR AP mode
IPAddress netMsk(255,255,255,0);         //FOR AP mode
const char* html = "<html><head><style></style></head>"
                   "<body><form action='/' method='GET'><input type='color' name='color' value='#000000'/>"
                   "<input type='submit' name='submit' value='Update RGB Strip'/></form></body></html>";
ESP8266WebServer server(80);
  strip.Begin();
  strip.Show();
//***************WIFI client************************//
  WiFi.begin(ssid, password);
  Serial.print("\n\r \n\rWorking to connect");
  Serial.println("");
  Serial.println(ssid);
  Serial.print("IP address: ");
//***************WIFI ACCESS POINT******************//
//  WiFi.mode(WIFI_AP);
//  WiFi.softAPConfig(apIP,apIP,netMsk);
//  WiFi.softAP(ssid,password);  //leave password away for open AP
//  Serial.print("SSID: ");
//  Serial.println(ssid);
//  Serial.print("IP address: ");
//  Serial.println(WiFi.softAPIP());
  server.on("/", handle_root);             //root page
  server.onNotFound(handleNotFound);       //page if not found
  server.begin();
  server.handleClient();
void handleNotFound() {
  Serial.print("\t\t\t\t URI Not Found: ");
  Serial.println(server.uri());
  server.send ( 200,"text/plain","URI Not Found" );
void handle_root() {
  String toSend = html;
  if (server.hasArg("color")) {
    String rgbStr = server.arg("color");  //get value from html5 color element
    toSend.replace("#000000",rgbStr);     //replace our default black with new color
    int rgb[3];                           //define rgb pointer for ws2812
    getRGB(rgbStr,rgb);                   //convert RGB string to rgb ints
    updateEntireStrip(rgb[0], rgb[1], rgb[2]);           //update strip
  server.send(200, "text/html", toSend);
  delay(100);
void getRGB(String hexRGB, int *rgb) {
  int rgbNum = (int)strtol(&hexRGB[1],NULL,16);
  rgb[0] = rgbNum >> 16;        //red
  rgb[1] = rgbNum >> 8 & 0xFF;  //blue
  rgb[2] = rgbNum & 0xFF;       //green
void updateEntireStrip(int red, int blue, int green) {
  RgbColor rgb = RgbColor(red, blue, green);
  for(int i=0; i < pixelCount; i++) {
    strip.SetPixelColor(i,rgb);
  strip.Show();
By SwiCago
#22964 So the command "strtol" which is used to convert a hex string into an inter crashes the ESP. I trie multiple variations of "strtol", using pointers, char buffers, longs int longs, ints. At least 10 variations from the interwebs and none seem to have worked so far.
The following also crashes the ESP ... LOL .. but no worries I'll figure something out for you ;)
Code: Select allvoid loop() {
   const char* string = "0x4d14";
   int val = (int)strtol(string,NULL,16);
   Serial.println(val);
   delay( 1000 );
  //server.handleClient();
By SwiCago
#22968 Hi Chris,
Here is a working sample...The only thing I could not test is the actual ws2812 update, but the color from web and converting it to numbers that the NeoPixelBus understands works.
I had to make my own hex string to int converter, because of strtol causing the esp to crash.
  strip.Begin();
  strip.Show();
  Serial.println("");
/*  WiFi.mode(WIFI_AP);
  WiFi.softAP(ssid);//,password);  //leave password away for open AP
  Serial.println(WiFi.softAPIP());   */
  server.begin();
    rgbStr.replace("%23","#"); //%23 = # in URI
    toSend.replace("#000000",rgbStr);     //replace our default black with new color, so when page loads our new color shows
  delay(100);
  hexRGB.toUpperCase();
  char c[7];
  hexRGB.toCharArray(c,8);
  rgb[0] = convertToInt(c[1],c[2]); //red
  rgb[1] = convertToInt(c[3],c[4]); //green
  rgb[2] = convertToInt(c[5],c[6]); //blue
int convertToInt(char upper,char lower)
  int uVal = (int)upper;
  int lVal = (int)lower;
  uVal = uVal >64 ? uVal - 55 : uVal - 48;
  uVal = uVal << 4;
  lVal = lVal >64 ? lVal - 55 : lVal - 48;
  return uVal + lVal;
  strip.Show();
