Any idea of what is the cause of this blocking situation at the TCP level?
Best regards
Fernando
Explore... Chat... Share...
fgomes wrote:Hi redflag2k, I didn't solved it, I will try to replicate it with a local icecast server and wireshark active running both on my laptop, in order to identify the difference between the network traffic profile when the requests are from the ESP8266 client and when they are from a working webradio client, to see if this can show us some clue to the problem... There are examples working with the ESP8266 but using the SDK/FreeRTOS instead of the Arduino platform.
Do you have any clue about this issue?
Best regards
Fernando
