BTW: the duration parameter of the URL is added by the logger, no need to have it in your URL.
Explore... Chat... Share...
Borstenhorst wrote:I guess DNS tries to resolve the IP as Domain which is obviously not possible. but this is just an assumption.
os_timer_arm(&connection_timer_elapsed, 60000, 1);
Borstenhorst wrote:Nothing is happening in user_main, put you stuff into the corresponding functions
I you want to to trigger the elapsed function every minute you'll need:Code: Select allos_timer_arm(&connection_timer_elapsed, 60000, 1);
