By Borstenhorst
#2940 this is not where it would belong.
Plase make sure you understand the program flow.
In at_base_cmd.c
at_setupCmdCipStartLog
os_timer_arm(&polling_timer, 1000, 1);
replace with
os_timer_arm(&polling_timer, 60000, 1);
in
polling_timer_elapsed
remove all the GPIO checking and add your ADC code.
By alonewolfx2
#2981 link seems to always open in your application.it can be problem with sebserver. maybe it be better to shut down the connection after sending data.
Code: Select allSEND OK
ALREDY CONNECT
SEND OK
ALREDY CONNECT
SEND OK
ALREDY CONNECT
SEND OK
ALREDY CONNECT
SEND OK
ALREDY CONNECT
