Moderator: Mmiscool
By iw2fvo
#35531 Pressing format it replies " 1 " and then frrezes for ever.
Using 1M modules gives the same result.
I do not realized the reason for which it run one time only.
Similar problem has been reported in other post by different user.
Thanks
Ambro
By Mmiscool
#35537 This one is kind of hard to diagnose.
I just flashed using the flasher and it seems to be working fine.
I put several demo programs on to the module and they saved fine each time.
Can you post the program you are trying to save and the output from the terminal of it saving and then the output of it not saving?
By iw2fvo
#35565 I flashed the esp module with LUA .
I found it working well.
I flashed the esp module using Basic : result is OK.
ESP (ap ) is on the wifi list.
I connected the AP.
"192.168.4.1/edit "set in the browser.
result on the web page is " Done ". NO other operations is allowed to me.
All these steps screen capture is attached hereafter.
Thanks
regards
Ambro
By iw2fvo
#35566 sorry for the "fedit " mistyiping !
Loaded the example fileand relevant terminal printout.
Thanks
Ambro
