Someone has acomplished this ?
Regards
PaulDG wrote:I managed to get the transmitter working from his examples but the receiver was more difficult, I had to ditch his timing loop and go with a simple timer in the main loop. I ended up sampling at 41 micro seconds.Code: Select allvoid loop() {
if ( micros() - PointA > 41 ) {
irrecv.pgti();
PointA = micros();
if (irrecv.decode(&results)) {
Serial.println(results.value);
delay(800); // Stops Key Bounce
irrecv.resume(); // Receive the next value
PaulDG
Thanks PaulDG for the inspiration. I had written my own bit-bang NEC code for transmit months ago and works fine but was having no joy with receiver. Once I took your approach of ditching the hardware timer it only took a couple of hours to get it working.
