Current News
Moderator: Mmiscool
By cicciocb
#46046 Hi all,
I worked recently on the ESPBasic introducing some new functions.
I'm happy to announce that a new version is coming with a full package of improvements.
Mike is already working on the integration and he should be able to put a new load probably tonight.
Here is an extract of the new features coming :
Release notes version cicciocb alpha 17:
- New structure commands :
- if then else endif
- do loop {until | while}
- Improved for command :
- the step can be defined
- Improved handling for goto / gosub / return
- Now it's mandatory to have labels between square brackets like [LABEL1]
- The label length is limited to 30 characters
- optimisation of ram memory
- more free memory available
-improved error handling
- more verbose error messages
- program stops when error is captured
- wrongly nested 'for / next' , 'if / else / endif', 'do / loop' are checked on open / save with associated warnings
- Increased the max length for the variable names from 10 to 30
- Addition of the <autorun> option in the 'Settings' page
- Improvement for the neopixel functions ; now it's possible to define the pin
- Improvement for the dht functions ; now it's possible to define the sensor (DHT11, DHT21, DHT22) and the pin
- Improvement for the function hex() ; now it's possible to define the number of digits
- Addition of the command gpio1reset permitting to restore the serial port communication
- addition of a full serialport #2 (can transmit and receive)
- Addition of the SPI functions
Detailed informations:
IF / THEN / ELSE / ENDIF
Is possible to use structured 'if then else endif'.
Example :
a = 50
b = 40
c = 30
d = 20
e = 10
if a > b then
print "a > b"
if b >c then
print "b > c"
if c > d then
print "c > d"
if d > e then
print "d > e "
else
print "d < e "
end if
else
print "c < d "
end if
else
print "b < c"
end if
else
print "a < b"
end if
The classic 'single line' is still valid such as :
if a > b then print "a > b" else print "b > a"
The 'end if' can be written also as 'endif'
At each file save / file open, the nested levels are checked and the errors
are printed; this permit to correct the code before run
DO LOOP { UNTIL | WHILE } condition
Is possible to use structured do loops, using the until or while condition.
Example (taken directly from Liberty Basic help)
'count to 10 using "loop while" and "loop until"
a = 0
b = 0
do
print a
a = a + 1
loop while a < 11
print
do
print b
b = b + 1
loop until b = 11
The loop is executed at least one time as the checking is done at the end of the loop.
FOR / next improvements
Is possible to use the optional 'step' keyword.
The value for step can be negative and not limited to integer value.
The variable after the next keyword is optional
Example :
for index = 20 to 2 step -1
print index
next index
for x = 0 to 3.14 step 0.1
print "The sine of " & x & " is " & sin(x)
next
A new option permit to disable the autorun of the 'default.bas' program.
Very useful during debug phase.
Neopixel functions improvement
A new command 'neosetpin( pin )' permit to define the pin used for NEOPIXELS
Example :
neosetpin(5) will define GPIO5
If neosetpin() is not used, the default pin remains GPIO15
DHT sensors improvements
A new command 'dht.setup( model, pin) permit to define the sensor mode and the pin used
The model can be :
11 for DHT11
21 for DHT21
22 for DHT22
The pin can be any valid pin.
Example (for DHT11 on pin GPIO4):
dht.setup(11, 4)
print dht.temp()
print dht.hum()
if dht.setup() is not used, the model and the pin are default to DHT21 and pin GPIO5
It is possible to add a 2nd optional argument to this function to define the number
of characters generated.
Example:
print hex(12) -> c
print hex(12, 2) -> 0c
print hex(2170) -> 87a
print hex(2170, 4) -> 087a
print hex(2170, 6) -> 00087a
The command 'gpio1reset() permit to recover the normal behaviour of the TX pin
Example:
for i = 1 to 5
po 1 0
delay 300
po 1 1
delay 300
next i
print "The serial port is blocked now"
delay 300
gpio1reset()
print "The serial port is unlocked now"
Addition of a full serialport #2
A new serial port has been included. This is now a software port so we can freely define
the pins for the TX and the RX.
The associated commands are :
serial2begin speed, TX_pin, RX_pin
Open the serialport2 channel.
The speed can be any value up to 115200.
The TX_pin and RX_pin can be any valid pin (except GPIO16).
TX_pin and RX_pin are optional and default to 2 (TX_pin) and 12 (RX_pin)
serial2end
Close the serialport2 channel.
serial2print var
print the var
serial2prinln
print the var adding <new line> at the end
serial2input var
get into var the byte received from the serial port (port 2)
serial2branch label
jumps to the label as soon as serial data are received (port 2)
Example (taken from the serialport 1 example)
memclear
print ramfree()
serial2branch [serial2in]
wait
[serial2in]
serial2input zz$
Serial2print “received:”
serial2println zz$
return
The SPI port has been enabled permitting to interface with SPI devices
The associated pins are :
SCK : GPIO14
MISO: GPIO12 (Master Input, Slave Output) (input for the ESP8266)
MOSI: GPIO13 (Master Output,Slave Input ) (output for the ESP8266)
The CS pin can be any pin.
The associated functions are :
spi.setup(speed, SPI_MODE, MSBFIRST) -> set speed and mode
Only the first argument is required, the other default to SPI_MODE0 and to MSB_FIRST
Example spi.speed(1000000, 0, 1) -> same as spi.speed(1000000)
var = spi.byte(val) -> read and write a byte at the same time (the arguments are numbers)
Example:
dat = spi.byte(55)
var$ = spi.string(string, len) -> write and receive a string of len chars
Example:
dat$ = spi.string("Hello World!", 12)
var$ = spi.hex(hex_string, len) -> write and receive a string containing an hexadecimal message representing len bytes
Example:
dat$ = spi.hex("a1b2c3d4e5f6", 6) -> send 6 bytes (sequence of a1, b2, c3, d1, e5, f6) and receive in dat$
This is an example of a Microchip MCP23S17 Expander connected to the ESP8266.
This chip permit to expand the I/O of the ESP8266 delivering 2 additional ports of 8 bits (PORT A and PORT B).
Each bit of each port can be individually set as output or input (with an optional pull-up).
The following example will set the PORT A as output and the PORTB as input.
Then a code from 0 to 255 is sent to the PORT A (assuming that 8 leds are connected);
at the same time, the port B is read and its value is printed into the console.
The CS is connected on the GPIO5.
memclear
cls
spi.setup(1000000, 0)
gosub [init.expander]
for i = 0 to 255
' write port A
add = 18
dat = (not i)
gosub [write_exp]
'read port B
add = 19
gosub [read_exp]
serialprintln dat
next i
end
' INIT THE MCP27S17 EXPANDER
[init.expander]
'disable HAEN (Hardware Address Enable)
add = 12 ' IOCON
dat = 0 ' disable HAEN
gosub [write_exp]
'set the expander with port A output
add = 0 'IODIRA
dat = 0 ' all outputs
gosub [write_exp]
'set the expander with port B input
add = 1 'IODIRB
dat = 255 ' all inputs
gosub [write_exp]
'set the expander with pull-up on port B inputs
add = 13 'GPPUB
dat = 255 ' all inputs pullup active
gosub [write_exp]
return
' WRITE to the MCP23S17 EXPANDER
' this function uses the variables
' add = address - INPUT -
' dat = data - INPUT -
[write_exp]
'chip select
po 5 0
spi.byte(64) 'writemode (0x40)
spi.byte(add)
spi.byte(dat)
po 5 1
return
' READ from the MCP23S17 EXPANDER
' dat = data - OUTPUT -
[read_exp]
'chip select
po 5 0
spi.byte(65) 'readmode (0x41)
spi.byte(add)
dat = spi.byte(dat)
po 5 1
return
CiccioCB
By forlotto
#46047 ugh holy moly!
Such Work! Many Improvments!
I am curious to see someone use the port expander that you talk of...
So would it allow say more ports for a relay?
There is a slight problem I have with newer versions.
The newer versions do not allow for DIO mode so a modded nodemcu cannot make use of the extra ports for relays for instance would be nice if this was a possible solution it may be the upgraded flasher I use to flash DIO mode is causing the problem as well I am not entirely sure what the jig is but when you need 8 ports for relays and you don't have old versions but yet you have the hardware purchased to build about 4 more devices it is kind of a buzz kill not a complaint by any means just curious if there is a solution to use GPIO 9 and 10 on mod versions that you are aware of I just need two more GPIO's thats it and I'm good to fly and the mod nodemcu allowed for this with old versions I don't know what is conflicting for sure as I cant find a copy of the older flasher from electrodragon. Anyhow back to my project.
