By surya arief
#67937 I want, if wifi connect to esp, then led is on,
if not connect, then led is off
but this below code not work, and ssid cannot scaned.
iam use NodeMcu V3.
#include <ESP8266WiFiMulti.h>
ESP8266WiFiMulti WiFiMulti;
const int led = 7; //pin on GPIO13 connected to LED
void setup(){
pinMode(led, OUTPUT);
digitalWrite(led, LOW); //turn off led
// set Wifi SSID and password
WiFiMulti.addAP("mywifi", "12345678");
void loop(){
// scanning wifi with SSID and password above
if ((WiFiMulti.run() == WL_CONNECTED))
{ digitalWrite(ledA, HIGH); //turn on led }
else
{digitalWrite(ledA, LOW); //turn off led }}
By atexit8
#68004 This code works for me.
const char* ssid = "ssid";
const char* password = "password";
  Serial.begin(9600);
  delay(10);
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);
  // Connect to WiFi network
  Serial.println(ssid);
   WiFi.begin(ssid, password);
  Serial.println("");
  //put your LED code here
By surya arief
#68013 Code above is esp8266 as client not accesspoint, if esp8266 connect to hotspot, then led is on.
is possible if i want esp8266 as accesspoint, not as client?
So if there is client connect to esp8266, then led is on.
By schufti
#68022
are you decided yet if the LED is on gpio 7 or 13 ?
If you intend to use nodemcu pin marked "D7" you should write
const int led = D7
or alternatively
const int led = 13
maybe that will make your code work ....
