Chat freely about anything...
By ZeSawyer
#71603 Hello!
Got a simple project. Decode an IR remote for 2 AC's, Daikin FTKC (split) and FFR10CV1 (Cassette). Then re-transmit the signal with an ESP8266.
Managed to control the split unit, but failed at the Cassette. Here are the steps & results:
Steps:
1. Use an IR receiver to decode the remote signal, all AC's share 1 remote controller.
2. Copy the raw data (uint32_t rawData[131] = {4500,2450, 400,350...).
3. Transmit the obtained data by the command: irsend.sendRaw(rawData, 131, 38).
Results:
The split AC responded quite well. The cassette AC, however, did not. I tried to send the command at each frequency from 25 to 45Khz but it's not responding.
- Any suggestions to what I might be doing wrong?
- If my circuit (as attached in the picture) works well with the split AC, should it work with any other devices as well? Or my hardware might be causing the problem?
By ZeSawyer
#71717 The IR LED is Vishay high power LED, which is why it could go up to 200mA with no issues.
I put an IR receiver and noticed some loss on the command sent, not sure whats causing it yet
