By doktorinjh
#74539 I am attempting to connect to this website, with zero success: https://liftie.info/api/resort/gunstock/
I have tried the HTTPSRequest sketch as a guideline, along with others, and I have never been able to establish a connection. The ESP8266 can connect to other https websites, but as soon as I try to make simple substitutions for liftie.info, the connect ceases. I've tried examples with and without the fingerprint, but it doesn't even appear to get that far before I get errors.
Is there the possibility that the .info domain is causing some sort of confusion?
Thanks for any help!
By doktorinjh
#74562 As a follow up, it looks like the website uses TLS 1.2, so I'll need to update my firmware(?) to be able to implement that. I'm not certain which version I'm using, but I'll check that to be sure. I'll be following this guideline, unless anyone has a better suggestion.
Thanks!
By doktorinjh
#74585 Update for those following along at home.
I turned on debugging and I get this message:
Code: Select allscandone
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 14
cnt
connected with nastar, channel 11
dhcp client start...
....ip:192.168.1.123,mask:255.255.255.0,gw:192.168.1.1
WiFi connected
IP address:
192.168.1.123
connecting to liftie.info
State:   sending Client Hello (1)
Alert: handshake failure
Error: SSL error 40
Alert: unexpected message
Error: SSL error 40
Alert: close notify
connection failed
0
pm open,type:2 0
Searching that error code brings this up: "Two cipher suites supported by axTLS library on the ESP side (TLS_RSA_WITH_AES_128_CBC_SHA and TLS_RSA_WITH_AES_256_CBC_SHA) are not among the list of cipher suites supported by your server." So unless I can add other cipher suites to the ESP or get the website to accept one of these two, then I won't be able to connect.
