By Antori91
#75686 Hello,
In one of my ESP8266 projects, the ESP reset/reboot from time to time due to Hardware Watchdog if the reason returned by ESP.getResetReason() is true.
In my Arduino program, I don't stop the Software Watchdog. In this case, how it is possible that Hardware Watchdog timeout happens and not **FIRST** Software Watchdog timeout?
Thanks in advance for your answers
By Antori91
#75768 It seems that I've solved the issue or at least seriously improved the situation. Below is the source code (with a lot of print added for debugging purpose!) I've used from a while to manage two of my house lighting areas. The two areas can be switched ON/OFF from many physical pushbuttons (connected to the ESP8266 GPIO via two latching relays !) and from an home automation software (Domoticz).
I've noticed that the ESP8266 resets only happens (with Hardware Watchdog reason given) when Switching ON or OFF the relays of the ESP8266 board. These relays are used to power on/off the lights. Adding a delay(2000) just after the relays switching seems to improve the situation. Is there anybody to give me some light on this? I use the same ESP8266 boards (coming from ElectroDragon) to manage heaters which use much power than a light and I've never noticed the same issue. Is it about inrush current when switching on the lights? But why a delay(2000) seems to avoid the Hardware Watchdog...It doesn't seem to me there is a reason that one watchdog or another bite when I switch ON/OFF the relays. There is many delay() around the code. And if the relays are not switched on/off, no watchdog bite. But if a watchdog should bite, why the Software Watchdog doesn't bite first. It's true that switching the relays generate a lot of electric noise which even impacts from time to time the USB/serial connection (bad/strange characters displayed at the screen a short period of time after the relays switching).
Code: Select all#include "WiFi_OTA_MQTT_SecretKeys.h"
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <PubSubClient.h>
#include <ArduinoJson.h>
// EDragon/ESP8266 board parameters
boolean ColdBoot                  = true;
#define FILTER                       3 // N+1 same readings every DELAY_FILTER ms must be read to validate GPIO reading !
#define DELAY_FILTER                25 // Delay in ms between two readings
#define Relay1                      12 // Digital Pin 12
#define Relay2                      13 // Digital Pin 13
#define GPIO4                        4 // GPIO-5 on SPDT connector
#define GPIO5                        5 // GPIO-4 on SPDT connector
// WiFi parameters
#define   NUMBER_OF_AP 4
byte      WiFi_AP    = 2; // The WiFi Access Point we are connected to
const     char *ssid[NUMBER_OF_AP]      = { WIFI_1,     WIFI_2,     WIFI_3,     WIFI_4 };
const     char *password[NUMBER_OF_AP]  = { WIFI_1_PWD, WIFI_2_PWD, WIFI_3_PWD, WIFI_4_PWD };
boolean   WiFiWasRenew = false;
#define   WiFiRetryDelay 2000 // Delay in ms between each WiFi connection retry
// MQTT parameters
byte          willQoS            = 0;
char          willMessage[MQTT_MAX_PACKET_SIZE+1];
boolean       willRetain         = false;
const char*   mqtt_server        = MQTT_SERVER_IP;
const char*   topic_Domoticz_IN  = "domoticz/in";
const char*   topic_Domoticz_OUT = "domoticz/out";
char          msgToPublish[MQTT_MAX_PACKET_SIZE+1];
WiFiClient    espClient;
PubSubClient  client(espClient);
#define       MQTTRetryDelay       2000 // Delay in ms between each MQTT connection retry
#define       MQTTMaxRetriesDelay  10  // if we didn't success to reconnect in that delay in mn, then restart the ESP
const int     MQTTMaxRetries     = MQTTMaxRetriesDelay * ( 60000 / ( 4000 + MQTTRetryDelay + FILTER*2*DELAY_FILTER ) ); // 4s is around the connection try duration
int           MQTTRetriesCounter = MQTTMaxRetries;
// Lighting parameters
String      LIGHTING[2]         = { "ENTREE", "MEZZANINE" }; //$$
String      LIGHT_SWITCH_IDX[2] = { "50", "51" };            // Corresponding DomoticZ switchs
String      LIGHT_ACTIVE[2]     = { "Off", "Off" };          // Lighting state (On or Off)
boolean     LIGHT_CHANGED[2]    = { true, true };            // Flag to know if we must update DomoticZ because people have changed Lighting state using home pushbuttons. Initialize to *true* to reset DomoticZ switchs at boot.
int         cstate_GM43[2];                                  // GM43 current device status
int         pstate_GM43[2];                                  // GM43 previous device status
const char* LIGHT_MQTT_ID       = "TWILIGHT";
void eventWiFi(WiFiEvent_t event) {
    Serial.println("== WiFi Event Received ==");
    switch(event) {
        case WIFI_EVENT_STAMODE_CONNECTED:
          Serial.print("[WiFi STA] "); /*Serial.print(event);*/ Serial.println(" Connected");
          break;
        case WIFI_EVENT_STAMODE_DISCONNECTED:
          Serial.print("[WiFi STA] "); /*Serial.print(event);*/ Serial.print(" Disconnected - Status :"); Serial.print(WiFi.status()); Serial.print(" "); Serial.println(connectionStatus( WiFi.status()));
          break;
        case WIFI_EVENT_STAMODE_AUTHMODE_CHANGE:
          Serial.print("[WiFi STA] "); /*Serial.print(event);*/ Serial.println(" AuthMode Change");
          break;
        case WIFI_EVENT_STAMODE_GOT_IP:
          Serial.print("[WiFi STA] "); /*Serial.print(event);*/ Serial.println(" Got IP");
          Serial.printf(" == SUCCESS - Connected to WiFi AP %s ==\n", WiFi.SSID().c_str());
          WiFiWasRenew = true;
          break;
        case WIFI_EVENT_STAMODE_DHCP_TIMEOUT:
          Serial.print("[WiFi STA] "); /*Serial.print(event);*/ Serial.println(" DHCP Timeout");
          break;
        case WIFI_EVENT_SOFTAPMODE_STACONNECTED:
          Serial.print("[WiFi AP] "); /*Serial.print(event);*/ Serial.println(" Client Connected");
          break;
        case WIFI_EVENT_SOFTAPMODE_STADISCONNECTED:
          Serial.print("[WiFi AP] "); /*Serial.print(event);*/ Serial.println(" Client Disconnected");
          break;
        case WIFI_EVENT_SOFTAPMODE_PROBEREQRECVED:
          Serial.print("[WiFi AP] "); /*Serial.print(event);*/ Serial.println(" Probe Request Received");
          break;
    }  // switch(event) {
} // void eventWiFi(WiFiEvent_t event) {
String connectionStatus( int which ) {
    switch ( which ) {
        case WL_CONNECTED:
        return "Connected";
        break;
        case WL_NO_SSID_AVAIL:
        return "AP not available";
        break;
        case WL_CONNECT_FAILED:
        return "Connect Failed";
        break;
        case WL_IDLE_STATUS:
        return "Idle status";
        break;
        case WL_DISCONNECTED:
        return "Disconnected";
        break;
        default:
        return "Unknown";
        break;
} // String connectionStatus( int which ) {
void setup() {   // ****************
   Serial.println("iot_EDRAGON_GM43_Lighting Booting - Firmware Version : 0.54");
   pinMode(Relay1,OUTPUT);
   pinMode(Relay2,OUTPUT);
   digitalWrite(Relay1, LOW);      // Lighting switch OFF
   digitalWrite(Relay2, LOW);
   pinMode(GPIO4,INPUT);
   pinMode(GPIO5,INPUT);
   pstate_GM43[0] = digitalReadF(GPIO4,false); cstate_GM43[0] = pstate_GM43[0];
   pstate_GM43[1] = digitalReadF(GPIO5,false); cstate_GM43[1] = pstate_GM43[1];
   // connect to WiFi Access Point
   WiFi.onEvent(eventWiFi);
   WiFi.mode(WIFI_STA);
   Serial.printf( "Trying to connect to preferred WiFi AP %s\n", ssid[WiFi_AP] );
   WiFi.begin(ssid[WiFi_AP], password[WiFi_AP]);
   while (WiFi.waitForConnectResult() != WL_CONNECTED) {
      PushbuttonsPressed(false);
      if( ++WiFi_AP == NUMBER_OF_AP ) WiFi_AP = 0;
      delay(WiFiRetryDelay);
      Serial.printf( "Trying to connect to WiFi AP %s\n", ssid[WiFi_AP] );
   } // while (WiFi.waitForConnectResult() != WL_CONNECTED) {
   // if ( MDNS.begin ( "esp8266" ) ) Serial.println ( "MDNS responder started" );
   // Port defaults to 8266
   // ArduinoOTA.setPort(8266);
   // Set OTA Hostname
   ArduinoOTA.setHostname(LIGHT_MQTT_ID);
   // Set OTA authentication password
   ArduinoOTA.setPassword((const char *)OTA_PWD);
   ArduinoOTA.onStart([]() {
    Serial.println("Start");
   ArduinoOTA.onEnd([]() {
    Serial.println("\nEnd");
   ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
    Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
   ArduinoOTA.onError([](ota_error_t error) {
    Serial.printf("Error[%u]: ", error);
    if (error == OTA_AUTH_ERROR)         Serial.println("Auth Failed");
    else if (error == OTA_BEGIN_ERROR)   Serial.println("Begin Failed");
    else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
    else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
    else if (error == OTA_END_ERROR)     Serial.println("End Failed");
   ArduinoOTA.begin();
   // MQTT
   client.setServer(mqtt_server, 1883);
   client.setCallback(callback);
   // say we are now ready and give configuration items
   Serial.println( "Ready" );
   Serial.print  ( "Connected to " ); Serial.printf ( "%s\n", ssid[WiFi_AP] );
   Serial.print  ( "IP address: " );  Serial.println( WiFi.localIP() );
   Serial.print  ( "Lighting " ); Serial.print(LIGHTING[0]); Serial.print(" set to : "); Serial.print(LIGHT_ACTIVE[0]); Serial.print(" - its GM43-GPIO4 is : "); Serial.println(cstate_GM43[0]);
   Serial.print  ( "Lighting " ); Serial.print(LIGHTING[1]); Serial.print(" set to : "); Serial.print(LIGHT_ACTIVE[1]); Serial.print(" - its GM43-GPIO5 is : "); Serial.println(cstate_GM43[1]);
} // void setup(  ****************
void callback(char* topic, byte* payload, unsigned int length) {   // ****************
   DynamicJsonBuffer jsonBuffer( MQTT_MAX_PACKET_SIZE );
   String messageReceived="";
   // Affiche le topic entrant - display incoming Topic
   Serial.print("\nEntering MQTT Callback. Message arrived regarding topic [");
   Serial.print(topic);
   Serial.println("]");
   // decode payload message
   for (int i = 0; i < length; i++) {
   messageReceived+=((char)payload[i]);
   // display incoming message
   // Serial.println(messageReceived);
   // if domoticz message
   if ( strcmp(topic, topic_Domoticz_OUT) == 0 ) {
        Serial.println("MQTT Callback. Parsing Domoticz Message arrived...");
        JsonObject& root = jsonBuffer.parseObject(messageReceived);
        if (!root.success()) {
           Serial.println("parsing Domoticz/out JSON Received Message failed");
           return;
        const char* idxChar = root["idx"];
        String idx = String( idxChar);
        Serial.print("MQTT Callback. This message is about Domoticz Device Idx=");Serial.println(idx);
        if ( idx == LIGHT_SWITCH_IDX[0] ) {
           const char* cmde = root["nvalue"];
           Serial.print("MQTT Callback. Light Command received="); Serial.println(cmde);
           if( strcmp(cmde, "0") == 0 ) {  // 0 means we have to switch OFF the lights
                if( LIGHT_ACTIVE[0] == "On" ) { Serial.print("MQTT Callback. Turning Off Lighting "); Serial.println(LIGHTING[0]); digitalWrite(Relay1, LOW); delay(2000); LIGHT_ACTIVE[0] = "Off"; }
           } else if( LIGHT_ACTIVE[0] == "Off" ) { Serial.print("MQTT Callback. Turning On Lighting "); Serial.println(LIGHTING[0]); digitalWrite(Relay1, HIGH); delay(2000); LIGHT_ACTIVE[0] = "On"; }
           Serial.print  ( "Lighting " ); Serial.print(LIGHTING[0]); Serial.print(" set from Domoticz to : "); Serial.print(LIGHT_ACTIVE[0]); Serial.print(" - its GM43-GPIO4 is : "); Serial.println(cstate_GM43[0]);
        }  // if ( idx == LIGHT_SWITCH_IDX[0] ) {
        if ( idx == LIGHT_SWITCH_IDX[1] ) {
                if( LIGHT_ACTIVE[1] == "On" ) { Serial.print("MQTT Callback. Turning Off Lighting "); Serial.println(LIGHTING[1]); digitalWrite(Relay2, LOW); delay(2000); LIGHT_ACTIVE[1] = "Off"; }
           } else if( LIGHT_ACTIVE[1] == "Off" ) { Serial.print("MQTT Callback. Turning On Lighting "); Serial.println(LIGHTING[1]); digitalWrite(Relay2, HIGH); delay(2000); LIGHT_ACTIVE[1] = "On"; }
            Serial.print  ( "Lighting " ); Serial.print(LIGHTING[1]); Serial.print(" set from Domoticz to : "); Serial.print(LIGHT_ACTIVE[1]); Serial.print(" - its GM43-GPIO5 is : "); Serial.println(cstate_GM43[1]);
        }  // if ( idx == LIGHT_SWITCH_IDX[1] ) {
   } // if domoticz message
   delay(15);
   Serial.println("Leaving MQTT Callback");
} // void callback(char* to   ****************
void reconnect() {   // ****************
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    String string;
    // Attempt to connect
    string = "{\"command\" : \"addlogmessage\", \"message\" : \"Lighting went Offline - IP : " +  WiFi.localIP().toString() + "\"}";
    string.toCharArray( willMessage, MQTT_MAX_PACKET_SIZE);
    // if ( client.connect(buf) ) {
    if ( client.connect( LIGHT_MQTT_ID, topic_Domoticz_IN, willQoS, willRetain, willMessage ) ) {
        Serial.println("connected");
        // suscribe to MQTT topics
        Serial.print("Subscribe to domoticz/out topic. Status=");
        if ( client.subscribe(topic_Domoticz_OUT, 0) ) Serial.println("OK"); else Serial.println("KO");
        // Wait ten seconds to try to be sure DomoticZ available after a DomoticZ server reboot (i.e. means avoid MQTT available but not yet DomoticZ)
        // delay(10000);
        // Say now "Me the lighting, I'm here"
        if( ColdBoot )
             string = "{\"command\" : \"addlogmessage\", \"message\" : \"iot_EDRAGON_GM43_Lighting Online - COLD BOOT Reason : " + ESP.getResetReason() + " - Firmware Version : 0.54 - SSID/IP/MAC : " + WiFi.SSID() + "/" + WiFi.localIP().toString() + "/" + WiFi.macAddress().c_str() + "\"}";
        else if ( WiFiWasRenew )
                  string = "{\"command\" : \"addlogmessage\", \"message\" : \"iot_EDRAGON_GM43_Lighting Online - WIFI CONNECTION RENEWED - SSID/IP/MAC : " + WiFi.SSID() + "/" + WiFi.localIP().toString() + "/" + WiFi.macAddress().c_str() + "\"}";
             else string = "{\"command\" : \"addlogmessage\", \"message\" : \"iot_EDRAGON_GM43_Lighting Online - MQTT CONNECTION RENEWED - SSID/IP/MAC : " + WiFi.SSID() + "/" + WiFi.localIP().toString() + "/" + WiFi.macAddress().c_str() + "\"}";
        string.toCharArray( msgToPublish, MQTT_MAX_PACKET_SIZE);
        Serial.print(msgToPublish);
        Serial.print("Published to domoticz/in. Status=");
        if ( client.publish(topic_Domoticz_IN, msgToPublish) ) Serial.println("OK"); else Serial.println("KO");
        ColdBoot = false; WiFiWasRenew = false;
    } else {
        Serial.print("MQTT connection failed, rc=");
        Serial.print(client.state());
        Serial.print(", MQTTRetriesCounter=");
        Serial.print( MQTTRetriesCounter );
        Serial.print(" - Try again in ");
        Serial.print( (int)(MQTTRetryDelay/1000) );
        Serial.println(" seconds");
        if( MQTTRetriesCounter-- == 0 ) ESP.restart();
        // Wait n seconds before retrying
        delay(MQTTRetryDelay);
    }  // if (client.connect
  } // while (!client.connected()) {
} // void reconnect() { ****************
int digitalReadF(int GPIO, boolean DoMqttWork) {
  int i;
  int Reading = digitalRead(GPIO);
  if( Reading != 0 && Reading != 1 ) {
      Serial.print("\n==== Error reading GPIO : ");
      Serial.println(GPIO);
  int NextReading;
  for( i=1; i <= FILTER ; i++ ) {
    if( DoMqttWork ) client.loop();
    delay( DELAY_FILTER );
    NextReading = digitalRead(GPIO);
    if( NextReading != 0 && NextReading != 1 ) {
    if( NextReading != Reading ) {
       i = 1;
       Reading = NextReading;
       Serial.print("\n==== Restarting reading GPIO : "); Serial.println(GPIO);
  return( Reading );
} // int digitalReadF(int GPIO, boolean DoMqttWork) {
void PushbuttonsPressed(boolean DoMqttWork) {  // ****************
  cstate_GM43[0] = digitalReadF(GPIO4,DoMqttWork);
  if( cstate_GM43[0] != 0 && cstate_GM43[0] != 1 ) {
      Serial.print("\n==== Error cstate_GM43[0] : ");
      Serial.println(GPIO4);
  if( cstate_GM43[0] != pstate_GM43[0] )  {
      Serial.print( "\nLighting is going to changed. " ); Serial.print(LIGHTING[0]); Serial.print(" was : "); Serial.print(LIGHT_ACTIVE[0]); Serial.print(" - its GM43-GPIO4 is now : "); Serial.println(cstate_GM43[0]);
      pstate_GM43[0] = cstate_GM43[0];
      LIGHT_CHANGED[0]=true;
      if( LIGHT_ACTIVE[0] == "Off") {
      } else {
      } // if( LIGHT_ACTIVE[0] == "Off") {
      Serial.print( "Lighting has changed. " ); Serial.print(LIGHTING[0]); Serial.print(" set from Pushbuttons to : "); Serial.print(LIGHT_ACTIVE[0]); Serial.print(" - its GM43-GPIO4 is : "); Serial.println(cstate_GM43[0]);
  } // if( cstate_GM43[0] != pstate_GM43[0] )  {
  cstate_GM43[1] = digitalReadF(GPIO5,DoMqttWork);
  if( cstate_GM43[1] != 0 && cstate_GM43[1] != 1 ) {
      Serial.print("\n==== Error cstate_GM43[1] : ");
      Serial.println(GPIO5);
  if( cstate_GM43[1] != pstate_GM43[1] )  {
      Serial.print( "\nLighting is going to changed. " ); Serial.print(LIGHTING[1]); Serial.print(" was : "); Serial.print(LIGHT_ACTIVE[1]); Serial.print(" - its GM43-GPIO5 is now: "); Serial.println(cstate_GM43[1]);
      pstate_GM43[1] = cstate_GM43[1];
      LIGHT_CHANGED[1]=true;
      if( LIGHT_ACTIVE[1] == "Off") {
      } else {
      } // if( LIGHT_ACTIVE[1] == "Off") {
      Serial.print( "Lighting has changed. " ); Serial.print(LIGHTING[1]); Serial.print(" set from Pushbuttons to : "); Serial.print(LIGHT_ACTIVE[1]); Serial.print(" - its GM43-GPIO5 is : "); Serial.println(cstate_GM43[1]);
  } // if( cstate_GM43[1] != pstate_GM43[1] )  {
}   // void PushbuttonsPressed(boolean DoMqttWork) ****************
void loop() {   // ****************
  if (!client.connected()) { // MQTT connection
    reconnect();
  ArduinoOTA.handle();
  String string;
  // Check if people have pressed a home pushbutton to change Lighting state
  PushbuttonsPressed(true);
  if(  LIGHT_CHANGED[0] )  {
      string = "{\"command\" : \"switchlight\", \"idx\" : " + LIGHT_SWITCH_IDX[0] + ", \"switchcmd\": \"" + LIGHT_ACTIVE[0] + "\"}";
      Serial.print(" Published to domoticz/in. Status=");
      if ( client.publish(topic_Domoticz_IN, msgToPublish) ) { LIGHT_CHANGED[0] = false; Serial.println("OK"); } else Serial.println("KO");
      Serial.print("GM43-GPIO4 is : "); Serial.println(cstate_GM43[0]);
  if(  LIGHT_CHANGED[1] )  {
      string = "{\"command\" : \"switchlight\", \"idx\" : " + LIGHT_SWITCH_IDX[1] + ", \"switchcmd\": \"" + LIGHT_ACTIVE[1] + "\"}";
      if ( client.publish(topic_Domoticz_IN, msgToPublish) ) {  LIGHT_CHANGED[1] = false; Serial.println("OK"); } else Serial.println("KO");
      Serial.print("GM43-GPIO5 is : "); Serial.println(cstate_GM43[1]);
  client.loop();
  delay(100);
} // void loop()  ****************
/* THE END */
By rudy
#75770 Disconnect the power to the relays, then run the code.
Disconnect the relays and run the code. Or run the code on a board that does not have the relays.
I don't know what kind of lights you have but many have very high inrush current. With incandescent the inrush is about ten times the normal current. If the lights are a modern electronic try the inrush current can even be a lot higher but for a shorter duration.
Do you have a link for the board you are dusing? Maybe post a picture of your setup.
By Antori91
#75783 Hello Rudy,
I use Electrodragon ESP8266 boards (with two relays on the PCB) : http://www.electrodragon.com/product/wi ... d-esp8266/
The corresponding electronic circuit board schematics is :
http://www.electrodragon.com/w/File:Esp ... d_r1.6.png
The lights (of the two areas) are powered on/off from the two relays on the ESP8266 board. The pushbuttons are connected to the coil commands of two latching relays (located at the main panel). The two latching relays outputs are used as two switches connected to GPIO 4 and 5. When a latching relay is open, the corresponding GPIO is +3.3V (pull up resistor on the board). When a latching relay is closed, the corresponding GPIO goes to Ground.
Obviously, I can't run the code without the relays. But I've noticed if I run the code and switch on/off the relays without the lights connected, there is no issue at all. The issue occurs only if the lights are connected and actually powered on/off. I did also some tests with incandescent lights and electronic bulbs, the issue occurs in both cases. As I already mentioned, the issue doesn't happen every time. It happens maybe every 20 relay switch on but of course It can happen two times in a row.
