By beic
#76553
Cosmic Mac wrote:And you can take advantage of C++ default parameters to simplify the code:
Code: Select allserver.on("/", handleRoot);
serverExt.on("/", handleRootExt);
void handleRootExt() {
   handleRoot(true)
void handleRoot(boolean blIsExtAccess = false) {
   String stData = "Hello there";
   if (blIsExtAccess == false) {
      server.send(200, "text/html", stData);
   } else {
      serverExt.send(200, "text/html", stData);
Another way would be to redirect Ext requests to the main server:
Code: Select allserverExt.on("/", []() {
   serverExt.sendHeader("Location", String("http://") + toStringIp(serverExt.client().localIP()), true);
   serverExt.send(302, "text/plain", "");
   serverExt.client().stop();
server.on("/", []() {
Untested... ;)
Thank you for your approach, I would use your 1st one, but I got error "'handleRoot' was not declared in this scope".
Just a note that my handleRoot function is in another Tab/Sketch.
Any further ideas?
By btidey
#76562 Not quite sure what you mean by 'handleRoot function is in another Tab/Sketch', but I assume that means you have the function in a different cpp file to the main sketch.
To make the handleRoot function available in your main sketch you should include a function declaration in your main sketch.
extern void handleRoot(boolean blIsExtAccess = false);
The extern keyword is optional but I like to make it explicit so I know it is defined elsewhere.
By beic
#76566
btidey wrote:Not quite sure what you mean by 'handleRoot function is in another Tab/Sketch', but I assume that means you have the function in a different cpp file to the main sketch.
Yes, the "handleRoot" function is in a different Sketch.
But, I got filtered out the issue with that, but I don't know what is causing that.
If the function declaration is like this:
Code: Select allvoid handleRoot(boolean blIsExtAccess = false)
I got an error mentioned before "'handleRoot' was not declared in this scope".
But, if I remove the function argument initial/optional value "= false"
Code: Select allvoid handleRoot(boolean blIsExtAccess)
In this case it will work, but need to define both, true or false when calling it.
Any suggestions?
By Cosmic Mac
#76567 Try to put the default value in the function declaration, not in the definition.
Declaration in foobar.h file:
Code: Select allvoid handleRoot(boolean blIsExtAccess = false);
Definition in foobar.cpp file:
Code: Select all#include "foobar.h"
void handleRoot(boolean blIsExtAccess) {
    // your code
