ESP8266 WIFI SoC! General News
Come follow us on Google+ Page
By Daniel PARENT
#77065 Hello,
I wish to use the ESP8266 to connect objects in WIFI.
For that I use the IDE ARDUINO to compile and load the program in memory.
Below the connection test program:
Cpp code:
Code: Select all    #include <ESP8266WiFi.h>
    const char* ssid = "Livebox-b82e"; // remplacer par le SSID de votre WiFi
    const char* password = "xxxxxxxxxxxxxxxxx"; // remplacer par le mot de passe de votre WiFi
    void setup(void){
      Serial.print("début");
    Serial.println(ssid);
    WiFi.begin(ssid, password);
    if(WiFi.status() != WL_CONNECTED)https://www.esp8266.com/posting.php?mode=post&f=4# {
        Serial.println("[loop] no wifi");
    } else {
        Serial.println("[loop] WiFi connected");
        Serial.print("[loop] IP address: ");
        delay(5000);
Lors de l'exécution j'ai des exceptions que je ne sais comment résoudre : ci-dessous le bavardage de la console
Code: Select alldébutConnecting to Livebox-b82e
[loop] no wifi
[loop] no wifi
Exception (0):
epc1=0x40226f9f epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: sys
sp: 3ffffb70 end: 3fffffb0 offset: 01a0
>>>stack>>>
3ffffd10:  40104921 4010491e ffffffff ffffffff
3ffffd20:  400005e1 ffffffff ffffffff ffffffff
3ffffd30:  40226f9f 00000033 0000001e ffffffff
3ffffd40:  40104927 402357e0 00000000 00000001
3ffffd50:  fbf8ffff 04000002 3feffe00 00000100
3ffffd60:  0000001a 00000018 04000102 40104908
3ffffd70:  3fffc100 3ffe97ac 00000000 00000000
3ffffd80:  ffffffff ffffffff ffffffff ffffffff
3ffffd90:  ffffffff ffffffff ffffffff ffffffff
3ffffda0:  ffffffff ffffffff ffffffff ffffffff
3ffffdb0:  ffffffff ffffffff ffffffff ffffffff
3ffffdc0:  ffffffff ffffffff ffffffff ffffffff
3ffffdd0:  ffffffff ffffffff ffffffff ffffffff
3ffffde0:  ffffffff ffffffff ffffffff ffffffff
3ffffdf0:  ffffffff ffffffff ffffffff ffffffff
3ffffe00:  00000005 00000000 00000020 40100ec6
3ffffe10:  3ffe8ed5 401042c3 3ffec960 ffffffff
3ffffe20:  40104921 4010491e 3ffed050 ffffffff
3ffffe30:  400005e1 000a0f4f 3ffed360 40101db2
3ffffe40:  40222a80 00000030 0000001e 00000001
3ffffe50:  40221c5c 00000000 3ffe97b6 3ffed42c
3ffffe60:  00000018 00000018 00000050 00000000
3ffffe70:  00000000 3ffe8ed5 3ffe8ed0 3ffe9136
3ffffe80:  3ffe97a0 3ffe97ac 00000000 00000000
3ffffe90:  3fffc278 40101f8c 3fffc200 00000022
3ffffea0:  3ffe975c 40214f8f 3ffed2ac 000a077a
3ffffeb0:  40000f68 00000030 0000001e ffffffff
3ffffec0:  40000f58 00000000 00000020 00000000
3ffffed0:  3ffe8d84 00000000 00000000 3ffe8004
3ffffee0:  00000001 3ffe8ed0 00000000 3fffdab0
3ffffef0:  00000000 3fffdcc0 3ffe8fb0 00000030
3fffff00:  3ffee190 3ffedae0 3ffed330 40209308
3fffff10:  00000000 00030490 4021897f 3ffedaa8
3fffff20:  3ffedae0 000a077a 60000600 3ffefa68
3fffff30:  3ffee978 00000164 00000164 4010020c
3fffff40:  40221c5c 00000000 3ffe97a0 3ffe97ac
3fffff50:  00000000 00000001 4010420e 40106e7c
3fffff60:  3ffed050 3ffe97b6 00000001 40221511
3fffff70:  3ffec960 3ffe97a0 3fffdcc0 3ffe8fb8
3fffff80:  00000050 3ffec960 00000002 00000000
3fffff90:  40220e63 3fffdab0 00000000 00000004
3fffffa0:  3ffe8fb8 40000f49 3fffdab0 40000f49
<<<stack<<<
 ets Jan  8 2013,rst cause:2, boot mode:(3,4)
tail 8
chksum 0x2d
csum 0x2d
v614f7c32
~ld
tail 8
chksum 0x2d
csum 0x2d
v614f7c32
~ld
tail 8
chksum 0x2d
csum 0x2d
v614f7c32
~ld
If anyone can help me: with all my thanks
cordially
By grhhm
#78506 This is likely not-matching Flash use. Check size of soldered flash chip. Compare the size with total Flash memory mapping for the compilation. It might consist of EEPROM + Firmware + SPIFFS. Total size should be equal or less the chip size.
