- Mon Dec 03, 2018 12:46 pm
#79398
that's funny, I'm working on that right now ...
I'm using SDK and I'm developing a web api for this
// [GET] /api/files/ls
// [GET] /api/files/cat/:name
// [POST] /api/files/delete/:name
// [POST] /api/files/create/:name
hope this will help you (and may your comments will help me ...)
cheers
listing looks like this (this is the web server receiving function, I've cut some code just for showing big view)
if ((0 == os_strcmp(parsed_req.url, "/api/files/ls")) && (parsed_req.req_method == HTTP_GET))
if (espfs.is_available()) // if file system is available
// count files first -> file_cnt
// now prepare the list
char *file_list = (char *)os_zalloc(32 + (file_cnt * (32 + 3)));
if (file_list)
char *tmp_ptr = file_list;
os_sprintf(file_list, "{\"files\":["); // returning results with a JSON string
// for listing with SPIFFS checkout SPIFFS using
// the following uses my C++ wrapper
file_ptr = espfs.list(0);
while (file_ptr)
tmp_ptr = file_list + os_strlen(file_list);
if (tmp_ptr != (file_list + os_strlen("{\"files\":[")))
*(tmp_ptr++) = ',';
os_sprintf(tmp_ptr, "\"%s\"", (char *)file_ptr->name);
file_ptr = espfs.list(1);
os_sprintf(tmp_ptr, "]}\n");
response(ptr_espconn, HTTP_OK, file_list, true);
return;
else
esplog.error("Websvr::webserver_recv - not enough heap memory\n");
return;
else
response(ptr_espconn, HTTP_SERVER_ERROR, "File system is not available\n", false);
return;
https://github.com/quackmore
