So it 's ok if I don't use it, right?
Explore... Chat... Share...
panoss wrote:In the following code the ' WiFi.softAP' does not work. Because the AP that is created has as host name the automatic name (ESP+ a number).
I have the 'wifiManager.startConfigPortal()' empty, without host name.
The ' WiFi.softAP' should go to some other place in the code?Code: Select all#include <ESP8266WiFi.h> //https://github.com/esp8266/Arduino
//needed for library
#include <ESP8266WebServer.h>
#include <DNSServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
#define TRIGGER_PIN D5
WiFi.mode(WIFI_STA);
Serial.println("\n Starting");
pinMode(TRIGGER_PIN, INPUT);
// is configuration portal requested?
if ( digitalRead(TRIGGER_PIN) == LOW ) {
Serial.println("Pulled LOW)");
WiFi.mode(WIFI_AP_STA);
WiFi.softAP("ThermometerReceiverAP", "1234");
//WiFiManager
//Local intialization. Once its business is done, there is no need to keep it around
WiFiManager wifiManager;
//reset settings - for testing
//wifiManager.resetSettings();
//sets timeout until configuration portal gets turned off
//useful to make it all retry or go to sleep
//in seconds
//wifiManager.setTimeout(120);
//it starts an access point with the specified name
//here "AutoConnectAP"
//and goes into a blocking loop awaiting configuration
//WITHOUT THIS THE AP DOES NOT SEEM TO WORK PROPERLY WITH SDK 1.5 , update to at least 1.5.1
//WiFi.mode(WIFI_STA);
if (!wifiManager.startConfigPortal()) {
Serial.println("failed to connect and hit timeout");
delay(3000);
//reset and try again, or maybe put it to deep sleep
ESP.reset();
delay(5000);
//if you get here you have connected to the WiFi
Serial.println("connected...yeey :)");
Serial.println("Pulled HIGH)");
RichardS wrote:Should be fine if you use
WiFi.softAP("newname"); or
WiFi.softAP("newname", "newpassword");
