Using the new Arduino IDE for ESP8266 and found bugs, report them here
By azimut2000
#81949 Hello,
I have a problem with TimeLib : when i use fixe IP address, i can't access to good time.
Here is en exemple that work on ESP8266 and ESP32 : it do the same bug, i allways stay in 1970 when i use fixe IP address.
#include <ESP8266WiFi.h>            // if ESP8266 plateform
//#include <WiFi.h>                     // if ESP32 plateform
#include <TimeLib.h>
#include <NtpClientLib.h>
const char* ssid = "xxxxxxxxxx;                 // Entrez le SSID du réseau WiFi
const char* password = "xxxxxxxxxxxxxxxxxx";    // Entrez le password du réseau WiFI
bool cnxMode = false;                           // Mode de reception @IP : false -> DHCP / true -> assignée
IPAddress MyIP(192,168,1,90);
IPAddress subnet(255, 255, 0, 0);
IPAddress gateway(192, 168, 1, 1);
IPAddress myDNS(8, 8, 8, 8);
  delay(100);
  WiFi.begin(ssid, password);
  // On attend d'être connecté
  unsigned long MyTime = millis();
    if (millis() >= ((20*1000) + MyTime) ) {  // si au bout de 20 secondes on est toujours dans la boucle...
      Serial.println("");
      Serial.println("On a dépassé le temps imparti pour la connexion : reboot !");
      ESP.restart();                          // ... on reboot !
  // On affecte une adresse par DHCP ou par IP Fixe
  if (cnxMode) {
    // Mode IP Fixe
    WiFi.config(MyIP, gateway, subnet, myDNS);
  } else {
    // Mode DHCP
  // On confirme la connexion à l'utilisateur en allumant la LED
  digitalWrite(LED_BUILTIN, LOW);
  NTP.begin (); // Only statement needed to start NTP sync.
  Serial.println("Nous sommes le " + String(day()) + " " + String(month()) + " " + String(year()));
What do you think of this ? Does someone have found a solution to work fine ?
Thank's for your ideas and answer.
Thierry
