Chat freely about anything...
By Jhon Doe
#83930 PWM works by pulsating DC current, and varying the amount of time that each pulse stays 'on' to control the amount of current that flows to a device such as an LED. ... PWM signals are typically square waves, like the one in the illustration below. A PWM signal (square wave) with a 50% duty cycle.
By parkjonasa
#84296 Pulse Width Modulation (PWM) is a fancy term for describing a type of digital signal. Pulse width modulation is used in a variety of applications including sophisticated control circuitry. A common way we use them here at SparkFun is to control dimming of RGB LEDs or to control the direction of a servo motor.
By ronakagarwal
#84434 A Pulse Width Modulation (PWM) Signal is a method for generating an analog signal using a digital source.
There are many different ways to control the speed of DC motors but one very simple and easy way is to use Pulse Width Modulation.
