eriksl wrote:It seems packet sniffer mode has been extended recently.
But I am totally lost as to why an IoT device would need sniffer mode.
Well, let me help you with a simple example -
a soho wireless intrusion detection system on a 5v chip.
Explore... Chat... Share...
Tanay Rami wrote:Hi, I am also facing same problem right now.
In my appplicatiion I want to send large amount of data between more than two ESPs.
With promiscous mode: if it is a managemenet frame then packet length is 128 bytes and if it is Data frame then packet length is 60 bytes. So maximum we can able to receive is only 128 bytes without any payload.
Although with the help of this function "wifi_send_pkt_freedom()" we can send much more data but "wifi_set_promiscuous_rx_cb()" only able to receive 128 bytes.
I am using ESP8266 SDK version 1.3.0.
Is their any alternative ways(or functions) are available to receive more data?
As mention above: "packet sniffer mode has been extended recently", so how much packet size is extended? whick SDK i need to use for that?
Thanks you!
OK, It's about 2 years ago, I've posted here about[…]
I run the Espressif supplied tools on the files to[…]
Since anything you ever want is on the Internet, I[…]
Once the command prompt’s black window appears, ty[…]
hi, tochange the interval I told you to change th[…]
I have a project ( A PID temperature controller) t[…]
https://www.esp8266.com/viewtopic.php?p=73027#p730[…]
so which compiler do you use? ... ;-) Apart from[…]
Hi, I didn't go through with the examples which Ma[…]
Follow US on Twitter and get ESP8266 news and updates first.
