By btidey
#85274 State machines are actually very simple and a good way of representing logic and timing in a maintainable way. The switch statement is at the heart of most state machines.
Take a look at the following where I try to represent your functionaity in a simple state machine. I haven't compiled or tested this but you should be able to see the flow.
Code: Select all#include <Arduino.h>
#include "fauxmoESP.h"
#define WIFI_SSID "lemainemachon"
#define WIFI_PASS "jibajaba"
#define REMOTE_BTN_1 4 //up (D2)
#define REMOTE_BTN_2 14//down (D5)
#define REMOTE_BTN_3 12  //select (D6)
#define REMOTE_BTN_4 5//stop (D1)
#define UP "blinds Up"
#define Down "blinds Down"
#define Light_Block "Blinds light Block"
fauxmoESP fauxmo;
#define STATE_IDLE 0
#define STATE_UP_START 1
#define STATE_UP_STOP 2
#define STATE_DOWN_START 3
#define STATE_DOWN_STOP 4
#define UP_DELAY 1000
#define DOWN_DELAY 1000
int state = STATE_IDLE;
unsigned long nextStateTime;
  // Init serial port and clean garbage
  // Wi-Fi connection
  wifiSetup();
  // Set Buttons
  pinMode(REMOTE_BTN_1, OUTPUT);          //up
  digitalWrite(REMOTE_BTN_1, HIGH);
  pinMode(REMOTE_BTN_2, OUTPUT);          //down
  digitalWrite(REMOTE_BTN_2, HIGH);
  pinMode(REMOTE_BTN_3, OUTPUT);          //select
  digitalWrite(REMOTE_BTN_3, HIGH);
  pinMode(REMOTE_BTN_4, OUTPUT);          //stop
  digitalWrite(REMOTE_BTN_4, HIGH);
  fauxmo.createServer(true); // not needed, this is the default value
  fauxmo.setPort(80); // This is required for gen3 devices
  fauxmo.enable(true);
  fauxmo.addDevice(UP);
  fauxmo.addDevice(Down);
  fauxmo.addDevice(Light_Block);
  fauxmo.onSetState([](unsigned char device_id, const char * device_name, bool state, unsigned char value) {                          //command recieved
    // Callback when a command from Alexa is received.
    Serial.printf("[MAIN] Device #%d (%s) state: %s value: %d\n", device_id, device_name, state ? "ON" : "OFF", value);
    if ( (strcmp(device_name, UP) == 0) ) {
      state = STATE_UP_START;
    if ( (strcmp(device_name, Down) == 0) ) {        //blinds down
      state = STATE_DOWN_START;
void stateMachine() {
   unsigned long m = millis();
   if(m > nextStateTime) {
      switch(state) {
         case STATE_IDLE :
            nextStateTime = m;
            break;
         case STATE_UP_START :
            digitalWrite(REMOTE_BTN_1, LOW);
            state = STATE_UP_STOP;
            nextStateTime = m + UP_DELAY;
            Serial.println("up started");
            break;
         case STATE_UP_STOP :
            state = STATE_IDLE;
            nextStateTime = m;
            Serial.println("up stopped");
            break;
         case STATE_DOWN_START :
            digitalWrite(REMOTE_BTN_2, LOW);
            state = STATE_DOWN_STOP;
            nextStateTime = m + DOWN_DELAY;
            Serial.println("down started");
            break;
         case STATE_DOWN_STOP :
            state = STATE_IDLE;
            nextStateTime = m;
            Serial.println("down stopped");
            break;
  fauxmo.handle();
  stateMachine();
// Wi-Fi Connection
void wifiSetup() {
  WiFi.mode(WIFI_STA);
  Serial.printf("[WIFI] Connecting to %s ", WIFI_SSID);
  WiFi.begin(WIFI_SSID, WIFI_PASS);
    Serial.print("attempting to connect to wifi");
    delay(100);
  Serial.printf("Connected to - SSID: %s, IP address: %s\n", WiFi.SSID().c_str(), WiFi.localIP().toString().c_str());
By GreenBlood
#85275 That’s interesting, will have a play:-)
btidey wrote:State machines are actually very simple and a good way of representing logic and timing in a maintainable way. The switch statement is at the heart of most state machines.
fauxmoESP fauxmo;
  // Wi-Fi connection
  wifiSetup();
  // Set Buttons
      switch(state) {
         case STATE_IDLE :
            nextStateTime = m;
            break;
            break;
            state = STATE_IDLE;
            nextStateTime = m;
            break;
            break;
            state = STATE_IDLE;
            nextStateTime = m;
            break;
  fauxmo.handle();
  stateMachine();
// Wi-Fi Connection
void wifiSetup() {
    delay(100);
By GreenBlood
#85279 I’ve studied the code, a very nice simpleish solution:-) will see if I get get it to play when I get some time to....play;-)
Cheers Steve
GreenBlood wrote:That’s interesting, will have a play:-)
fauxmoESP fauxmo;
  // Wi-Fi connection
  wifiSetup();
  // Set Buttons
      switch(state) {
         case STATE_IDLE :
            nextStateTime = m;
            break;
            break;
            state = STATE_IDLE;
            nextStateTime = m;
            break;
            break;
            state = STATE_IDLE;
            nextStateTime = m;
            break;
  fauxmo.handle();
  stateMachine();
// Wi-Fi Connection
void wifiSetup() {
    delay(100);
