By Bonzo
#85280 I have just done a test:
Uploaded the code un altered from https://randomnerdtutorials.com/alexa-e ... more-53313
Connected a LED and resistor to GPIO14 (D5)
Found devices on the echo (Phillips lamps)
LED was already on
Told echo to turn lamp 2 on and LED goes off
Turn lamp off and LED comes on
I think it is always better to get the code working and then add or remove code as you have a good starting point.
By GreenBlood
#85282 I’ve just done the same but removed the rf functionality. I can’t get alexa to register the lamps.
Of course, I started with this, maybe removing the rf code, I wonder if I’ve removed something essential....
Bonzo wrote:I have just done a test:
LED was already on
By Bonzo
#85283 My echo is new and all I have added to it is a Sinric skill which I used for the other Alexa code.
I have found two devices with this code; both "Royal Philips Electronics smart device". I had other fauxmo code I tried last weekend which didn't find a device. This code gave me a compile error but that was down to an old version of fauxmo and obviously that is not your problem as you can compile and upload your code.
This the output I am getting from the serial monitor:
[MAIN] Free heap: 49584 bytes
[MAIN] Free heap: 49080 bytes
[MAIN] Device #1 (lamp two) state: ON value: 255
RELAY 2 switched by Alexa
[MAIN] Device #1 (lamp two) state: OFF value: 255
I assume the registering of the lamps is not hardware dependant as I only have one LED connected. I am afraid I can not help further and just wanted to let you know the code will work ;) All very frustrating.
