You can chat about native SDK questions and issues here.
By saif_iot
#86179 Memory (heap) out after +100 TLS request with custom x509 root certificate
What to do to produce the error:
1 - Use ESP-IDF Example https_mbedtls
2 - Get root certificate of your server (self signed in my case) by using OpenSSL command: openssl s_client -showcerts -servername *.mydomain.com -connect MyServerIP:443 </dev/null 2>/dev/null|openssl x509 -outform PEM >/home/me/Desktop/server_root_cert.pem
3 - In menuconfig add custom certificate to the custom bundle CONFIG_MBEDTLS_CUSTOM_CERTIFICATE_BUNDLE_PATH="/home/me/Desktop/server_root_cert.pem"
4 - Build the firmware and flash..
It's will work great, but on every request mbedTLS allocate around ~2000 bytes on handshake stage, so after around ~120 requests we get a out of memory warning.
Note: I get free heap size by using ESP_LOGW(TAG, "Free Heap: %d", esp_get_free_heap_size());
Monitor log
Code: Select all--- idf_monitor on /dev/ttyUSB1 115200 ---
--- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
ets Jun  8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:4
load:0x3fff0034,len:7224
load:0x40078000,len:13092
load:0x40080400,len:3936
0x40080400: _init at ??:?
entry 0x40080688
I (28) boot: ESP-IDF v4.2-dev-701-g0ae960f2f-dirty 2nd stage bootloader
I (29) boot: compile time 15:53:08
I (30) boot: chip revision: 1
I (33) boot_comm: chip revision: 1, min. bootloader chip revision: 0
I (40) boot.esp32: SPI Speed      : 40MHz
I (45) boot.esp32: SPI Mode       : DIO
I (50) boot.esp32: SPI Flash Size : 2MB
I (54) boot: Enabling RNG early entropy source...
I (60) boot: Partition Table:
I (63) boot: ## Label            Usage          Type ST Offset   Length
I (70) boot:  0 nvs              WiFi data        01 02 00009000 00006000
I (78) boot:  1 phy_init         RF data          01 01 0000f000 00001000
I (85) boot:  2 factory          factory app      00 00 00010000 00100000
I (93) boot: End of partition table
I (97) boot_comm: chip revision: 1, min. application chip revision: 0
I (104) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x2e1c4 (188868) map
I (185) esp_image: segment 1: paddr=0x0003e1ec vaddr=0x3ffb0000 size=0x01e2c (  7724) load
I (189) esp_image: segment 2: paddr=0x00040020 vaddr=0x400d0020 size=0x85194 (545172) map
0x400d0020: _stext at ??:?
I (399) esp_image: segment 3: paddr=0x000c51bc vaddr=0x3ffb1e2c size=0x01b18 (  6936) load
I (402) esp_image: segment 4: paddr=0x000c6cdc vaddr=0x40080000 size=0x00404 (  1028) load
0x40080000: _WindowOverflow4 at /home/me/Desktop/MY_FIRMWARE/SDK/ESP_IDF/components/freertos/xtensa/xtensa_vectors.S:1817
I (406) esp_image: segment 5: paddr=0x000c70e8 vaddr=0x40080404 size=0x14be4 ( 84964) load
I (463) boot: Loaded app from partition at offset 0x10000
I (463) boot: Disabling RNG early entropy source...
I (464) cpu_start: Pro cpu up.
I (467) cpu_start: Application information:
I (472) cpu_start: Project name:     https-mbedtls
I (478) cpu_start: App version:      1
I (482) cpu_start: Compile time:     Mar 23 2020 15:52:59
I (488) cpu_start: ELF file SHA256:  3e4cef9cc8901077...
I (494) cpu_start: ESP-IDF:          v4.2-dev-701-g0ae960f2f-dirty
I (501) cpu_start: Starting app cpu, entry point is 0x40081280
0x40081280: call_start_cpu1 at /home/me/Desktop/MY_FIRMWARE/SDK/ESP_IDF/components/esp32/cpu_start.c:273
I (0) cpu_start: App cpu up.
I (511) heap_init: Initializing. RAM available for dynamic allocation:
I (518) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (524) heap_init: At 3FFB9530 len 00026AD0 (154 KiB): DRAM
I (531) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (537) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (543) heap_init: At 40094FE8 len 0000B018 (44 KiB): IRAM
I (550) cpu_start: Pro cpu start user code
I (568) spi_flash: detected chip: generic
I (569) spi_flash: flash io: dio
W (569) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
I (579) cpu_start: Starting scheduler on PRO CPU.
I (0) cpu_start: Starting scheduler on APP CPU.
I (685) wifi:wifi driver task: 3ffc0e0c, prio:23, stack:3584, core=0
I (685) system_api: Base MAC address is not set
I (685) system_api: read default base MAC address from EFUSE
I (705) wifi:wifi firmware version: d76a2dd
I (705) wifi:config NVS flash: enabled
I (705) wifi:config nano formating: disabled
I (705) wifi:Init dynamic tx buffer num: 32
I (715) wifi:Init data frame dynamic rx buffer num: 32
I (715) wifi:Init management frame dynamic rx buffer num: 32
I (725) wifi:Init management short buffer num: 32
I (725) wifi:Init static rx buffer size: 1600
I (735) wifi:Init static rx buffer num: 10
I (735) wifi:Init dynamic rx buffer num: 32
I (745) example_connect: Connecting to my_wireless...
I (835) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0
I (835) wifi:mode : sta (c4:4f:33:3e:c1:c5)
I (845) example_connect: Waiting for IP
I (965) wifi:new:<1,0>, old:<1,0>, ap:<255,255>, sta:<1,0>, prof:1
I (965) wifi:state: init -> auth (b0)
I (965) wifi:state: auth -> assoc (0)
I (975) wifi:state: assoc -> run (10)
I (1005) wifi:connected with my_wireless, aid = 23, channel 1, BW20, bssid = b4:fb:e4:e5:41:c0
I (1005) wifi:security type: 3, phy: bgn, rssi: -65
I (1005) wifi:pm start, type: 1
I (1045) wifi:AP's beacon interval = 102400 us, DTIM period = 1
I (1675) esp_netif_handlers: sta ip: 192.168.165.191, mask: 255.255.255.0, gw: 192.168.165.1
I (1675) example_connect: Got IP event!
I (2675) example_connect: Got IPv6 event!
I (2675) example_connect: Connected to my_wireless
I (2675) example_connect: IPv4 address: 192.168.165.191
I (2675) example_connect: IPv6 address: fe80:0000:0000:0000:c64f:33ff:fe3e:xxxx
I (2685) example: Seeding the random number generator
I (2695) example: Attaching the certificate bundle...
I (2695) example: Setting hostname for TLS session...
I (2705) example: Setting up the SSL/TLS structure...
W (2715) example: Free Heap: 206168 <<----------------------------------------
I (2715) example: Connecting to 192.168.168.XX:443...
I (2735) example: Connected.
I (2735) example: Performing the SSL/TLS handshake...
I (2845) esp-x509-crt-bundle: Certificate validated
I (3795) example: Verifying peer X.509 certificate...
I (3795) example: Certificate verified.
I (3795) example: Cipher suite is TLS-ECDHE-RSA-WITH-AES-256-GCM-SHA384
I (3805) example: Writing HTTP request...
I (3815) example: 103 bytes written
I (3815) example: Reading HTTP response...
HTTP/1.1 200 OK
Date: Tue, 24 Mar 2020 12:04:51 GMT
Server: Apache/2.4.37 (centos) OpenSSL/1.1.1c mod_fcgid/2.3.9
Last-Modified: Thu, 12 Mar 2020 18:08:25 GMT
ETag: "15-xxxx"
Accept-Ranges: bytes
Content-Length: 21
Connection: close
Content-Type: text/html; charset=UTF-8
<html>...</html>
I (3855) example: Completed 1 requests
I (3855) example: 10...
I (13855) example: 0...
I (14855) example: Starting again!
W (14855) example: Free Heap: 204212 <<----------------------------------------
I (14855) example: Connecting to 192.168.168.XX:443...
I (14865) example: Connected.
I (14865) example: Performing the SSL/TLS handshake...
I (14985) esp-x509-crt-bundle: Certificate validated
I (15935) example: Verifying peer X.509 certificate...
I (15935) example: Certificate verified.
I (15935) example: Cipher suite is TLS-ECDHE-RSA-WITH-AES-256-GCM-SHA384
I (15945) example: Writing HTTP request...
I (15955) example: 103 bytes written
I (15955) example: Reading HTTP response...
HTTP/1.1 200 OK
Date: Tue, 24 Mar 2020 12:05:03 GMT
ETag: "15-xxxx"
Content-Length: 21
Connection: close
<html>...</html>
I (15995) example: Completed 2 requests
I (15995) example: 10...
I (25995) example: 0...
I (26995) example: Starting again!
W (26995) example: Free Heap: 202984 <<----------------------------------------
I (26995) example: Connecting to 192.168.168.XX:443...
I (27005) example: Connected.
I (27005) example: Performing the SSL/TLS handshake...
I (27135) esp-x509-crt-bundle: Certificate validated
I (28115) example: Verifying peer X.509 certificate...
I (28125) example: Certificate verified.
I (28125) example: Cipher suite is TLS-ECDHE-RSA-WITH-AES-256-GCM-SHA384
I (28125) example: Writing HTTP request...
I (28135) example: 103 bytes written
I (28135) example: Reading HTTP response...
HTTP/1.1 200 OK
Date: Tue, 24 Mar 2020 12:05:15 GMT
ETag: "15-xxxx"
Content-Length: 21
Connection: close
<html>...</html>
I (28195) example: Completed 3 requests
I (28195) example: 10...
I (38195) example: 0...
I (39195) example: Starting again!
W (39195) example: Free Heap: 201760 <<----------------------------------------
I (39195) example: Connecting to 192.168.168.XX:443...
I (39205) example: Connected.
I (39205) example: Performing the SSL/TLS handshake...
I (39325) esp-x509-crt-bundle: Certificate validated
I (40315) example: Verifying peer X.509 certificate...
I (40315) example: Certificate verified.
I (40315) example: Cipher suite is TLS-ECDHE-RSA-WITH-AES-256-GCM-SHA384
I (40325) example: Writing HTTP request...
I (40325) example: 103 bytes written
I (40335) example: Reading HTTP response...
HTTP/1.1 200 OK
Date: Tue, 24 Mar 2020 12:05:27 GMT
ETag: "15-xxxx"
Content-Length: 21
Connection: close
<html>...</html>
I (40365) example: Completed 4 requests
I (40365) example: 10...
I (50375) example: 0...
I (51375) example: Starting again!
W (51375) example: Free Heap: 200532 <<----------------------------------------
I (51375) example: Connecting to 192.168.168.XX:443...
I (51385) example: Connected.
I (51385) example: Performing the SSL/TLS handshake...
I (51525) esp-x509-crt-bundle: Certificate validated
I (52545) example: Verifying peer X.509 certificate...
I (52545) example: Certificate verified.
I (52545) example: Cipher suite is TLS-ECDHE-RSA-WITH-AES-256-GCM-SHA384
I (52545) example: Writing HTTP request...
I (52555) example: 103 bytes written
I (52555) example: Reading HTTP response...
HTTP/1.1 200 OK
Date: Tue, 24 Mar 2020 12:05:39 GMT
ETag: "15-xxxx"
Content-Length: 21
Connection: close
<html>...</html>
I (52595) example: Completed 5 requests
I (52595) example: 10...
I (62595) example: 0...
I (63595) example: Starting again!
W (63595) example: Free Heap: 199308 <<----------------------------------------
I (63595) example: Connecting to 192.168.168.XX:443...
I (63605) example: Connected.
I (63605) example: Performing the SSL/TLS handshake...
I (63715) esp-x509-crt-bundle: Certificate validated
I (64705) example: Verifying peer X.509 certificate...
I (64705) example: Certificate verified.
I (64705) example: Cipher suite is TLS-ECDHE-RSA-WITH-AES-256-GCM-SHA384
I (64705) example: Writing HTTP request...
I (64715) example: 103 bytes written
I (64715) example: Reading HTTP response...
HTTP/1.1 200 OK
Date: Tue, 24 Mar 2020 12:05:52 GMT
ETag: "15-xxxx"
Content-Length: 21
Connection: close
<html>...</html>
I (64755) example: Completed 6 requests
I (64755) example: ...
If you see the heap size, we lose ~2000 bytes on every requests.
Code: Select allW (2715) example: Free Heap: 206168
The example work fine without custom certificate, this problem is only when adding custom x509 root certificate by menuconfig
Code: Select all#
# Certificate Bundle
CONFIG_MBEDTLS_CERTIFICATE_BUNDLE=y
CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_DEFAULT_FULL=y
# CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_DEFAULT_CMN is not set
# CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_DEFAULT_NONE is not set
CONFIG_MBEDTLS_CUSTOM_CERTIFICATE_BUNDLE=y
# end of Certificate Bundle
Thank you,
