By mesut
#86311 sorry for my english.
esp8266 I strive to create a new driver programming environment. I am also looking forward to a solution. I like this "name": "NodeMCU 1.0 (ESP-12E Module)" as it wants a hex or bin file of the card.
I am sending some pictures and projects. The codes I created for the trial are working in Arduino. mblok5 install and try
please one of you to take this project and find a solution.
a1, a2, a3 also want a .bin or .hex file.
NodeMCU 1.0 (ESP-12E Module) Is the card used in the arduino a hex or .bin file?
By mesut
#86317 this topic is an arduino whole topic. therefore, the code generated is arduino. and this programming logic and driver settings and files must be ordino. mblok supports 5 arduino.
