By mchahn
#88963 I have googled uart breaks on esp8266 and found that support is lacking for break characters in general. Correct me if I'm wrong.
I've seen two methods to send a break, both of which are messy. One is to send a zero byte with a slow baud rate. The other method is to turn off serial, use the gpio, and turn serial back on. I will use one of these ugly methods to send breaks.
However, I can't find anything about how to detect a break when receiving. From my testing it appears that Serial.read() just returns a byte value of zero which is useless.
Does anyone know a way to detect a received break? I'm stuck on this because the protocol I'm receviing uses breaks to separate transmissions.
By mrburnette
#89011 https://en.wikipedia.org/wiki/Break_key
As there are multiple implementations, I would try to detect Ctrl-C as that is most likely the better choice. Otherwise, you can create a sketch that reads all characters and output the ASCII code to a display.
You can modify my project to output ASCII numbers for non-printable characters.
https://www.hackster.io/rayburne/the-qbf-signal-generator-ae7015
