By LaurenzEdelmann
#88970 Hello, I am a beginner working with a NodeMCU ESP8266 for a university project. I have soldered the pins of the board off because I will be using it in a wristband, so I need to save space. Halfway through soldering, I plugged the board into my PC and it still worked. However, once I had soldered all the pins off, it no longer responds. When I plug it into my PC, the blue LED by the RST button is constantly on. Did I short a connection? If so, which one? Is the board broken? Any help is much appreciated. There are pictures of the board while plugged in below. Thanks in advance.
By QuickFix
#88979 It's impossible for us to judge what went wrong by just looking at some description and pictures: you obviously did something wrong with it.
Since it's a university project, I suggest you do the next:
  • Ditch this board
  • Buy a new one
  • Develop the software (and hardware on a breadboard if applicable) on the new board
  • When everything works (after much tweaking and testing) get a Wemos, which is smaller than a NodeMCU and doesn't have soldered on pins, and use that one instead
    If you feel like (you're up to) it, you could even take a separate ESP module (not to develop with, but in your final design), but then you have to design all peripherals, like PSU, yourself: it will get you extra points though.
By LaurenzEdelmann
#88985 Alright, thanks for the info. I think I destroyed a connection on the PCB or something, since if I press around on the board sometimes the LED next to the antenna (which flashes when the controller is connected to power, or when uploading a sketch) flashes. I even managed to upload a sketch, but clearly there is some sort of loose contact somewhere.
Thanks anyway! Good thing these boards are cheap!
By schufti
#88988 optically it looks ok, but you may have removed / broken one of the copper interconnects between the top/bottom layer on the pcb. Look at the removed pins for any minute "copper tubes" sitting on them.
