I am implementing some ESP8266 device with deep sleep + wifi. I want the device to sleep long, wake up, measure, send out data and sleep again. The standard IoT use case, I thing.
But the WiFi connection takes very long. Sometimes even more than 10 seconds.
Hardware:
I tested
- an Sparkfun ESP8266 Thing Dev and
- an ESP12f
with two different WiFis (one FritzBox and one Smartphone Hotspot).
Both ESP devices are more or less equal in the connection time. The smartphone WiFi replies the IP faster.
Can anyone tell my why I read a lot about ESP8266 devices connect within 2-3 seconds but my devices are so much slower???
Code here:
#include <Arduino.h>
#include <AsyncMqttClient.h>
#define logf(msg, ...) \
Serial.printf("%d ", millis()); \
Serial.printf("[%s] ", __FUNCTION__); \
Serial.printf(msg, __VA_ARGS__); \
Serial.printf("\n");
#define log(msg) \
Serial.printf(msg); \
WiFiEventHandler wifiDiconnectEventHandler;
time_t lastSend = 0;
void OnWiFiEvent(WiFiEvent_t event) {
switch(event) {
case WiFiEvent_t::WIFI_EVENT_STAMODE_CONNECTED:
log("WIFI connected.");
break;
case WiFiEvent_t::WIFI_EVENT_STAMODE_DISCONNECTED:
break;
case WiFiEvent_t::WIFI_EVENT_STAMODE_GOT_IP:
logf("WIFI got ip '%s'.", WiFi.localIP().toString().c_str());
break;
default:
printf("WIFI unhandled event %d", event);
void onStationModeDisconnected(const WiFiEventStationModeDisconnected& event) {
logf("WIFI disconnected. Reason %d", event.reason);
WiFi.persistent(false);
WiFi.mode(WIFI_STA);
WiFi.onEvent(OnWiFiEvent, WiFiEvent_t::WIFI_EVENT_ANY);
wifiDiconnectEventHandler = WiFi.onStationModeDisconnected(
[](const WiFiEventStationModeDisconnected& event) { onStationModeDisconnected(event); });
log("WIFI connecting.");
WiFi.begin("myWifi", "SoSafePassword");
void loop () {
if ( (millis()-lastSend) > 5000) {
lastSend = millis();
logf("Heap %d, Wifi %d", ESP.getFreeHeap(), WiFi.isConnected());
delay(1);
Sample printout here:
␀r␘␂␀l��r�␀�#␂�n�␄��␌␘�␌␜��␜p�<���␀�8␂��ǒ��l␜p␌␘␌�nn�␂�;�nĒ��␌␛�␌b�#l`␛$`␛␄nn��܀␌␜���l␜����␌␜�␌b�␄n��n�䎒␌␟�␌b��>~�n�␃����␀l`␛��␒�#�n�␄␎r␘␂␎␂nr���;␂��␌?␌␂�;�␂␎r�ےn�␄␎�b��l`␛Ğ�␌␟��␜␂��␃r�;�␂��n�b�
72 [setup] WIFI connecting.
3811 [onStationModeDisconnected] WIFI disconnected. Reason 203
5001 [loop] Heap 49640, Wifi 0
7683 [OnWiFiEvent] WIFI connected.
9350 [OnWiFiEvent] WIFI got ip '10.42.178.28'.
10002 [loop] Heap 48896, Wifi 1
␀r␘␂␀l��r�␀�#␂�n�␄��␌␘�␌␜��␜p�<���␀�8␂��ǒ��l␜p␌␘␌�nn�␂�;�nĒ��␌␛�␌b�#l`␛$`␛␄nn��܀␌␜���l␜����␌␜�␌b�␄n��n��␎�␌␟�␌b�ľ~�n�␃����␀l`␛��␒�#�n�␄�r␘␂␎␂nr���;␂��␌?␌␂�;�␂␎r�ےn�␄��b��l`␛Ğ�␌␟��␜␂��␃r�␂��n�b�
71 [setup] WIFI connecting.
3809 [onStationModeDisconnected] WIFI disconnected. Reason 203
7681 [OnWiFiEvent] WIFI connected.
9354 [OnWiFiEvent] WIFI got ip '10.42.178.28'.
␀r␘␂␀l��r�␀�#␂�n�␄��␌␘�␌␜��␜p�<���␀�8␂��ǒ��l␜p␌␘␌�nn�␂�;�nĒ��␌␛�␌b�#l`␛$`␛␄nn���␀␌␜���l␜����␌␜�␌b�␄n��n�䎒␌␟�␌b�ľ~�n�␃����␀l`␛��␒�#�n�␄�r␘␂␎␂nr���;␂��␌?␌␂�␂␎r�ےn�␄��b��l`␛Ğ�␌␟��␜␂��␃r�;�␂��n�b�
68 [setup] WIFI connecting.
5002 [loop] Heap 49640, Wifi 0
7678 [OnWiFiEvent] WIFI connected.
9326 [OnWiFiEvent] WIFI got ip '10.42.178.28'.
10003 [loop] Heap 48896, Wifi 1
␀r␘␂␀l��r�␀�#␂�n�␄��␌␘�␌␜��␜p�<���␀�8␂��ǒ��l␜p␌␘␌�nn�␂�;�nĒ��␌␛�␌b�#l`␛$`␛␄nn��܀␌␜���l␜����␌␜�␌b�␄n��n�䎒␌␟�␌b�ľ~�n�␃����␀l`␛��␒�#�n�␄�r␘␂␎␂nr���;␂��␌?␌␂�;�␂␎r�ےn�␄��b��l`␛Ğ�␌␟��␜␂��␃r�;�␂��n�b�
3807 [onStationModeDisconnected] WIFI disconnected. Reason 203
7676 [OnWiFiEvent] WIFI connected.
␀r␘␂␀l��r�␀�#␂�n�␄��␌␘�␌␜��␜p�<���␀�8␂��ǒ��l␜p␌␘␌�nn�␂�;�nĒ��␌␛�␌b�#l`␛$`␛␄nn��܀␌␜���l␜����␌␜�␌b�␄n��n�䎒␌␟�␌b��>~�n�␃����␀l`␛��␒�#�n�␄␎r␘␂␎␂nr���;␂��␌?␌␂�␂␎r�ےn�␄␎�b��l`␛Ğ�␌␟��␜␂��␃r�␂��n�b�
70 [setup] WIFI connecting.
7677 [OnWiFiEvent] WIFI connected.
9352 [OnWiFiEvent] WIFI got ip '10.42.178.28'.
␀r␘␂␀l��r�␀�#␂�n��␌␘�␌␜��␜p�<���␀�8␂��ǒ��l␜p␌␘␌�nn�␂�;�nĒ��␌␛�␌b�#l`␛$`␛␄nn��܀␌␜���l␜����␌␜�␌b�␄n��n�䎒␌␟�␌b�ľ~�n�␃����␀l`␛��␒�#�n�␄␎r␘␂␎␂nr���;␂��␌?␌␂�;�␂␎r�ےn�␄␎�b��l`␛Ğ�␌␟��␜␂��␃r�␂��n�b�
Other network:
67 [setup] WIFI connecting.
3825 [onStationModeDisconnected] WIFI disconnected. Reason 2
4979 [OnWiFiEvent] WIFI connected.
5001 [loop] Heap 48968, Wifi 0
6857 [OnWiFiEvent] WIFI got ip '192.168.43.91'.
␀r␘␂␀l��r�␀�#␂�n��␌␘�␌␜��␜p�<���␀�8␂��ǒ��l␜p␌␘␌�nn�␂�;�nĒ��␌␛�␌b�#l`␛$`␛␄nn��܀␌␜���l␜����␌␜�␌b�␄n��n�䎒␌␟�␌b�ľ~�n�␃����␀l`␛��␒�#�n�␄�r␘␂␎␂nr���;␂��␌?␌␂�;�␂␎r�ےn�␄␎�b��l`␛Ğ�␌␟��␜␂��␃r�;�␂��n�b�
4815 [onStationModeDisconnected] WIFI disconnected. Reason 202
7689 [OnWiFiEvent] WIFI connected.
9359 [OnWiFiEvent] WIFI got ip '192.168.43.91'.
␀r␘␂␀l��r�␀�#␂�n�␄��␌␘�␌␜��␜p�<���␀�8␂��ǒ��l␜p␌␘␌�nn�␂�;�nĒ��␌␛�␌b�#l`␛$`␛␄nn��܀␌␜���l␜����␌␜�␌b�␄n��n�䎒␌␟�␌b��>~�n�␃����␀l`␛��␒�#�n�␄�r␘␂␎␂nr���;␂��␌␡␌␂�␂␎r�ےn�␄��b��l`␛Ğ�␌␟��␜␂��␃r�;�␂��n�b�
3832 [onStationModeDisconnected] WIFI disconnected. Reason 2
4982 [OnWiFiEvent] WIFI connected.
6838 [OnWiFiEvent] WIFI got ip '192.168.43.91'.
␀r␘␂␀l��r�␀�#␂�n��␌␘�␌␜��␜p�<���␀�8␂��ǒ��l␜p␌␘␌�nn�␂�;�nĒ��␌␛�␌b�#l`␛$`␛␄nn���␀␌␜���l␜����␌␜�␌b�␄n��n��␎�␌␟�␌b�ľ~�n�␃����␀l`␛��␒�#�n�␄�r␘␂␎␂nr���;␂��␌?␌␂�;�␂␎r�ےn�␄��b��l`␛Ğ�␌␟��␜␂��␃r�;�␂��n�b�
3822 [onStationModeDisconnected] WIFI disconnected. Reason 2
4967 [OnWiFiEvent] WIFI connected.
6831 [OnWiFiEvent] WIFI got ip '192.168.43.91'.
␀r␘␂␀l��r�␀�#␂�n�␄��␌␘�␌␜��␜p�<���␀�8␂��ǒ��l␜p␌␘␌�nn�␂�;�nĒ��␌␛�␌b�#l`␛$`␛␄nn��܀␌␜���l␜����␌␜�␌b�␄n��n��␎�␌␟�␌b��>~�n�␃����␀l`␛��␒�#�n�␄�r␘␂␎␂nr���;␂��␌?␌␂�␂␎r�ےn�␄␎�b��l`␛Ğ�␌␟��␜␂��␃r�;�␂��n�b�
4853 [OnWiFiEvent] WIFI connected.
6834 [OnWiFiEvent] WIFI got ip '192.168.43.91'.
