By Bonzo
#89593 Thank you for the heads up eriksl; I originally built a unit that is working last year but want to make it smaller. I had it working with SPIFFS or a SD card.
I just thought I would check what I was using in the SD version and I can't find the code anywhere :cry:
Phew I found it and seem to be using:
#include <SPI.h>
#include <SD.h>
By eriksl
#89599 If you're going to store moderate amounts of data I'd recommend using a variant with 4 Mbyte flash and if that's not enough, you can opt for replacing it with a larger flash chip, IIRC it can be up to 16 Mbyte bit I'd have to check. Your program needs to be in the first 4 Mbyte, but I guess that won't be an issue. And the access to flash outside your "program area" (region 0-3 of 1 Mbyte chunks) needs to be addressed using flash_read calls, it can't be mapped to memory space like the program area.
By Bonzo
#89600 One reason I went with the SD version rather than the SPIFFS in the end was storage space; I didn't know how large the files would be at the time.
Looking back my largest file for half a day was 2.527KB and I should be able to fit plenty of those into the flash memory. I would like about a weeks storage as I am only usually away for that length of time.
That would save a bit more space as I would not need an SD card at all. I might get a smaller GPS unit so it will be down to about the same size as the battery; especially if I use an external charger.
I will have to do some investigation as I assume SPIFFS is different from what you are suggesting eriksl.
By eriksl
#89602 SPIFFS is something you can incorporate into your own code, but I think it's also in arduino, not sure what you're using...
SPIFFS is a file system. It must be used on top of a storage medium, be it flash or SD. If you insist using files, yes, that's a requirement. If writing blobs is sufficient, you don't really need a complete file system. Just make somethnig FAT-like, with a root directory and pointers to sectors. If all blobs are less than 4k, you don't even need an allocation table.
