By shiningthing
#91522 I use Winsock in Visual Basic 6 which has ASCII string data. I want to send that data to ESP8266 with TCP/IP Protocol, also from ESP8266 to VB6. Is this possible? If so, how it works? I've tried using the http port but it still doesn't work. Thank you in advance
By shiningthing
#91530
JurajA wrote:it is a standard communication over a TCP/IP network
I used this code but it didn't work. Is there something wrong with this code? If I want to pass the string to a modulator-demodulator, how do I do that?
const char* ssid = "xxx"; //SSID Access Point
const char* password = "123"; //Password Access Point
const char* host = "http://192.168.100.1";
//Client-ESP8266 IP Address
IPAddress IP(192,168,100,200);
IPAddress NETMASK(255,255,255,0);
IPAddress NETWORK(192,168,100,1);
IPAddress DNS(192,168,100,1);
  Serial.begin(1200);
  delay(100);
   // Connecting to a WiFi network
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  Serial.println("");
   WiFiClient client;
   Serial.printf("\n[Connecting to %s ...", host);
  if (client.connect(host, 80))
      Serial.println("connected]");
      Serial.println("[Sending a request]");
      client.print(String("GET /") + " HTTP/1.1\r\n" +
                   "Host: " + host + "\r\n" +
                   "Connection: close\r\n" +
                   "\r\n"
      Serial.println("[Response:]");
      while (client.connected() || client.available())
        if (client.available()){
          String line = client.readStringUntil('\n');
          Serial.println(line);
      client.stop();
      Serial.println("\n[Disconnected]");
        else
          Serial.println("connection failed!]");
          client.stop();
    delay(5000);
